Page 6 of 6 1 2 3 4 5 6
#1077037 02/02/05 02:57 AM
Originally posted by mcfast:
I had the same thing now for A few months. After a few test I think I found my problem. Test #1, Put in new spark plugs NGK IRIDUMS std gap 54 ran good for 3 weeks after that runing bad agan. Test #2, New spark plug wires, look at the plugs did not look good, gap to 40 ran good but I went ahead put in some new spark plugs MotorCraft AGSF32PPM thay do not make them any more I put in some replacement MotorCraft plug std gap 54, run good for a week after that
runing bad agan. Test #3, So today I completely clean my IMRC and put in some new pulgs, AUTOLITE APP764 gap to 40 so far so good we will see in a couple weeks if she is still runing good I think I have a weak coil.
Will my problem is back. I think I am going to throw this car in the garbage and buy some jap sh&t!!!!!!!!!!! or maybe a new Mustang
SVT 99 #526 of 2760
#1077038 02/02/05 05:55 AM
My car had the same low RPM--hard acceleration bucking problem. Turns out my number 6 spark plug wire was just a little loose. Ford Racing wires, BTW.
* Marine Officer Candidate * My Cardomain Page 1998 EO Black SVTC #3388
#1077039 02/06/05 03:31 PM
Week 11, still running great! I think this will be my last post on this one, unless it starts running bad agan. knock on wood
Last week my car started running bad agan, boy was I piss off! So today I took the ignition off the car and tested my coils, spark plug wires, look at the plugs, my coils are in spec,wires ok, plugs good, so I cleaned all the parts with carb cleaner, after that with brake cleaner, then I put some ignition protector on my wires and coil, after that I put some dielectric compound on all connectors, made suer all terminals fit tight, after I install all the parts I went for a test drivr, for now she running great, we will see how long it last this time.
SVT 99 #526 of 2760
