Posts: 300 |
Originally posted by Derk2000: Originally posted by mcfast: Try gaping your plugs at 40 thou. And see what happens.
If my car has run 75K with plugs gapped at .054, gapping them to .040 would be a band-aid fix to the problem. Don't you think?
YES I do. But it is better runing good with a band-aid then runing bad with out. When my car runs bad I feel bad so a little band-aid makes me feel good. (joke)
SVT 99 #526 of 2760
Posts: 300 |
Originally posted by mcfast: I had the same thing now for A few months. After a few test I think I found my problem. Test #1, Put in new spark plugs NGK IRIDUMS std gap 54 ran good for 3 weeks after that runing bad agan. Test #2, New spark plug wires, look at the plugs did not look good, gap to 40 ran good but I went ahead put in some new spark plugs MotorCraft AGSF32PPM thay do not make them any more I put in some replacement MotorCraft plug std gap 54, run good for a week after that runing bad agan. Test #3, So today I completely clean my IMRC and put in some new pulgs, AUTOLITE APP764 gap to 40 so far so good we will see in a couple weeks if she is still runing good I think I have a weak coil.
Day 4 still runing good! After I got laid-off two weeks ago it gave me time to work on my car. But good things have to end I start a new job tomorrow.
SVT 99 #526 of 2760
Posts: 300 |
Day #5 Monday sill running good. I think I am falling in love agan.(with my car)
SVT 99 #526 of 2760
Posts: 300 |
To day. Day #6 still runing prefect. I will be stoping my daily up dates tomorrow and going to weekly up dates. So be patient.
SVT 99 #526 of 2760
Posts: 2,118 |
I am having the exact problems and symptoms you have talked about in the first post.
I have new wires and plugs and the problem went away. I will try gapping the plugs to .40, this is all you did to fix it?
Is there any way to tell a weak coil pack? I really need to do the intake rebuild/cleaning and see whats going on with my motor. The missing throughout 1000-4000rpms is REALLY getting to me, and I know it can't be good for the longevity of my motor.
"Moore has also accused the American people of being the stupidest, most naive people on the face of the Earth. And after last weekend, he's got the box office numbers to prove it!"
Posts: 300 |
Originally posted by 99blacksesport: I am having the exact problems and symptoms you have talked about in the first post.
Yes, I think it was only the plugs set at 40 and not the rebuild/cleaning of the intake. To test the coil pack you will need a check the resistant. I do not have the spec. I am going to do that soon. I would all so check all the contacts for corrosion.
SVT 99 #526 of 2760
Posts: 300 |
Originally posted by mcfast: Originally posted by 99blacksesport: I am having the exact problems and symptoms you have talked about in the first post.
And go with DOUBLE PLATINUM PLUGS! 100%. I USED AUTOLITE APP764
SVT 99 #526 of 2760
Posts: 300 |
Day # 7 Still going strong. I will be going to a weekly update now. The only thing I can think of is when I wash the engine bay the water damage the coil pack some how? When I first got the car last year it ran strong at low RPMs That is the only thing I can see. I hope these post help some one. I have seen a lot of complains on these sites of similar problems.
SVT 99 #526 of 2760
Posts: 4,713 |
I thought about water and the coilpack...but then I couldn't remember the last time I sprayed my engine bay...
Derek
Scion xB 5-spd
Previous: 2000 Silver Frost SVT
Please share the road with cyclists.
Posts: 300 |
Originally posted by Derk2000: I thought about water and the coilpack...but then I couldn't remember the last time I sprayed my engine bay...
If I remember right. My problem began right after I wash the engine bay the first time. But I am not a 100% certain.
SVT 99 #526 of 2760
