Posts: 120 |
What is the difference between the early orange svt injectors and the later green svt injectors?
I have been told on here that they are both 19lb/hr.
Posts: 3,570 |
both are 19lb, orange is for return-style fuel system, green is for return-less fuel system.
This information is available using the search function.
Posts: 10,015 |
Basically the green and orange ones do not interchange due to the style of fuel rail and fuel system - return vs. returnless.
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
Posts: 120 |
Thanks for the response.
I also did search under maintance with "injector," and found nothing. At least you anwsered the question unlike other a**hole search nazis.
Posts: 9,602 |
Originally posted by Stazi: Basically the green and orange ones do not interchange due to the style of fuel rail and fuel system - return vs. returnless.
Sure they do.
You just need to change to the matching harness connectors.
Only the early side feed injectors physically mounted differently.
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 21,197 |
I have the pencil style on my '96.
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 3,570 |
Originally posted by todras: I have the pencil style on my '96.
meee too dood!
Posts: 21,197 |
You wired in new injectors?
-'96 SE MTX 3L
Posts: 3,570 |
watchyoo talkin' 'bout? I used the orange 19 lbsers, clicked into my stock wiring harness. But they look the same as the green ones (besides color obviously). Pencil style. No re-wiring needed.
Posts: 21,197 |
Pencil are different than your side feed.
-'96 SE MTX 3L
