What is the difference between the early orange svt injectors and the later green svt injectors?
I have been told on here that they are both 19lb/hr.
98' Contour SVT lots of go fast mods check em out: http://www.prism.gatech.edu/~gtg285m/
both are 19lb, orange is for return-style fuel system, green is for return-less fuel system.
This information is available using the search function.
Basically the green and orange ones do not interchange due to the style of fuel rail and fuel system - return vs. returnless.
Thanks for the response.
I also did search under maintance with "injector," and found nothing. At least you anwsered the question unlike other a**hole search nazis.
Sure they do.
You just need to change to the matching harness connectors.
Only the early side feed injectors physically mounted differently.
I have the pencil style on my '96.
meee too dood!
You wired in new injectors?
watchyoo talkin' 'bout? I used the orange 19 lbsers, clicked into my stock wiring harness. But they look the same as the green ones (besides color obviously). Pencil style. No re-wiring needed.
Pencil are different than your side feed.
