#1075065 10/11/04 06:52 PM
Driver Offline OP
The other day I noticed a knocking noise from the engine bay of my 2000 SVT contour. The noise is intermittent and happens only at idle RPMs. If I hear the knocking noise, I rev the car a bit and the noise goes away but returns once the revs go back to idle. I did some research and it looks like these cars have a lot of problems with spun bearings and a spun bearing makes a bad knocking noise. I am hoping that the knocking noise is a bad pulley since the noise is coming from that side of the engine and is intermittent and only occurs at idle. How do I tell if I have a spun bearing or have a bad pulley? The car drives fine.
#1075066 10/11/04 07:47 PM
N
N
Just for sheets & giggles. When you press in on the clutch does the noise go away? I doubt that's it, but my car makes a noticeable "racket" when the clutch isn't engaged at idle.
#1075067 10/12/04 12:40 AM
my zetec does the exact same thing (as nate's tour). Its been doing it for about 5000 miles, and nothing has come of it.
#1075068 10/12/04 02:00 PM
Driver Offline OP
The noise has not come back since I have posted this thread. Since I have been reading some of problems with spun bearings, I guess I am a little paranoid about any new sound coming from the engine bay especially if it sounds like a knock. I do think the noise will come back since cars can't fix themselves. Can anyone confirm if there is a knocking noise caused by a spun bearing that the noise is not intermittent and gets louder at higher RPMs?
