Posts: 4 |
Greetings all... I just purchased a '99 SVT over the weekend and couldn't be happier. My wife thinks the stupid grin on my face is just about the funniest thing she's ever seen  I do have on question though. We testdrove the car and everything was fine, but after pulling into my Grandmother's house (gotta bring the greatgrandchild over or I'd be in soooo much trouble) we could not get the car to go into reverse. Fortunately her driveway is on a hill so we just coasted backwards and were off. A few miles down the road we pulled into a Wendy's and I took the shifter bag off and noticed there was some sort of stop bolted into the block at the base of the stick. Using my trusty utility knife I unscrewed the bolt and removed the stop and now everything is working fine. My only question is do any of you have any idea why there might be a stop placed over the reverse gear? As I said, everything seems to be working fine... I just want to make sure it wasn't there for a reason.
Posts: 21 |
I'm not to sure, but that sounds like the reverse lock out? It's to prevent someone from shifting from 1st to reverse or some other terribly destructive shift. Either way, I can't say for sure as I suck and have an automatic. Go go CD4E  !
Former owner of a
1995 Contour
2.5L V6 ATX
Posts: 2,725 |
Originally posted by Strife: It's to prevent someone from shifting from 1st to reverse or some other terribly destructive shift.
Thats impossible! Reverse gear is handled by a small idler gear. At all times, the reverse gear is turning in a direction opposite to all of the other gears. Therefore, it would be impossible to throw the transmission into reverse while the car is moving forward the dog teeth would never engage. However, they will make a lot of noise!
Posts: 4 |
I'll try to post a picture of it tonight, might help  Thanks for the quick responses BTW.
Posts: 392 |
Sounds to me s stupid mod if someone do that. There is no chance you do a bad shift, shifting in reverse when you wnaa go n reverse. The reverse in under the 5th, to the complete opposite of the first gear. Why don't you haven't try reverse while doing your test drive before buying? this way you were able to ask the previous owner. Sounds weird!
Nic.
P.S. The only time i saw a car with no reverse or lock up, the car was use for drag racing.
Contour 99 MTX V6 fully loaded, stock with 110000km. Illuminated sunroof switch. About to do the mystique rear dome light conversion with eyeball dome light.
Posts: 392 |
I'm feeling stupid, i think i know what you mean. You have a lock up on MTX tour ( i do an MTX). If you don't know how it works, here is the answer:
Put your thumb on the top of the shifter knob; Using two fingers, put them bjust below the shifter knob ball, there is a king of ring, you have to lift it up.
Now to be sure, if you go straightly into reverse without doing any action of this kind, you removed the lockup. That lockup device should be on.
Nic.
Posts: 6,791 |
Reverse lock out... you gotta love it. I remember when i first bought my 99 SVT and discovered it. I was trying to back out of a parking space but couldnt get it in reverse. It took me about 3 minutes to figure it out. I felt like an idiot!
Posts: 106 |
Originally posted by RawBurt: Reverse lock out... you gotta love it. I remember when i first bought my 99 SVT and discovered it. I was trying to back out of a parking space but couldnt get it in reverse. It took me about 3 minutes to figure it out. I felt like an idiot!
aww now i thought i was the only one... yea i sat there and was like man its hard to get this car in reverse.. and then i did it and i didnt know what i did so didnt want to take it out of reverse... man that was so funny!!!
Posts: 4 |
My first thought was there was some type of lockout but I couldn't find anything to press and it felt like there was something actually blocking the shifter from going in to gear. I started feeling things through the bag and could tell there was definitely something there. I played around with removing the bag and finally just ripped it off (which is actually what you're supposed to do, so that worked well) and this is what I found.
Image 1
This picture is to illustrate how it blocked the shifter when I tried to put it in reverse:
Image 2
The third image is of the actual bolt and 'head' I took out. I have since reinstalled the bolt, minus the head.
Image 3
Posts: 5,143 |
Originally posted by blktour: Originally posted by RawBurt: Reverse lock out... you gotta love it. I remember when i first bought my 99 SVT and discovered it. I was trying to back out of a parking space but couldnt get it in reverse. It took me about 3 minutes to figure it out. I felt like an idiot!
Nope, you werent the only one, when my dad and I took my tour' for a test drive we spent about 2 or 3 minutes playing with it.
And on my brother's old 96 Jetta GL, you had the push the entire shifter down to push it into reverse.
98 Corolla LE 1.8L DOHC 1ZZFE
TEIN H.Tech Springs
Tokico HP series Struts
Short ram air intake
Tsudo Axel Back Exhaust
