Page 3 of 3 1 2 3
#1073837 10/14/04 12:25 PM
PCV valve leak or intake manifold gasket leaks will do it!
#1073838 10/14/04 12:31 PM
did they use new gaskets when they installed the headers?? a leak near the o2 sensor can through off the A/F reading
and since you are checking the UIM gaskets go ahead and clean that baby up, like others said it makes a difference, and when you look at it on the inside, you will see why it makes a difference
98.5 Black SE ATX S&B filter, SVT MAF, optimized SVT TB, mesh grille, removed orange reflectors, painted rear reflector, gutted pre-cats, optimized SVT LIM, 19lb injectors, resonator removed cant afford an svt but lookin for 1 in nc
#1073839 10/14/04 12:49 PM
If you cannot get the Berryman's B12(IIRC) in a can to pour in to the UIM to clean it, grab some Valvoline Throttle Body Cleaner - that stuff's just as good; just melts that black goop away like it's sugar!
#1073840 10/15/04 03:17 AM
9
All new gaskets and hardware were used, i.e. studs, nuts, bolts, and sensors. I do plan to have the intake thoroughly cleaned as well as replace all the PCV hoses/lines; I'm reframing this problem by looking at it as an opportunity to do some well-deserved maintenance to the engine. Thanks again for all your help guys.
Originally posted by LUCA:
Yep. You can be Phil too if you'd like.
#1073841 11/09/04 02:49 AM
Any update on the culprit?
2000 Contour SE 2.5L ATX - Toreador Red 2001 VW Golf GLS 2.0L MTX - Tornado Red Buy my possessed VCR!!
Page 3 of 3 1 2 3
