Posts: 2,241 |
is there any dyno information before/after quaife LSD? Fidenza? Spec Clutch? i'm interested mostly in eliminating drivetrain loss, i've got a spec clutch, fidenza, LSD, and very very beefy motor mounts. i think they might be TOO beefy...
-Matt
"Pain heals, chicks dig scars, and glory lasts forever!"
will do/pay just about anything for the following parts:
CF sunroof glass replacement
OEM CF trunk
Non OEM style cf or fiberglass hood not the cf1 design
Posts: 9,602 |
It would be exactly .4758473845643% more efficient when comparing it to something less efficient.
Flywheel - faster revving, less initial kinetic energy, less mass to rotate at high rpm. Good in 1st, great in 2nd, okay in 3rd, negiglable in 4th.
Clutch - It won't slip and take heat MUCH better! It's actually a hair heavier.
LSD - more parasitic loss, more power to the ground (being as both wheels get the power not just one when traction fails), BULLETPROOF.
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 2,241 |
the lsd provides more parasitic loss? really?
-Matt
OEM CF trunk
Posts: 213 |
Originally posted by Speed Demon: the lsd provides more parasitic loss? really?
I belive that it has to do with power being dristributed evenly through both the left and right wheels as opposed to the wheel with least resistance. Power usage at both wheels, rotational resistance through two paths, etc.
'98 CSVT
3L Hybrid
"It all comes down to how fast you want your money to go."
______________________________________________
View Profile
Posts: 9,602 |
"Technically" it does.
The amount is fairly miniscule.
It has more "gear to gear" contact then a normal open differential.
2000 SVT #674
Posts: 2,241 |
danke heir ... other... demon
-Matt
OEM CF trunk
Posts: 4,693 |
Most LSD systems do have a slight parasitic loss, and I'm sure that this one does as well, but since it distributes the power more evenly to the wheels, it can help make the power that gets to the wheels more usable, especially under heavy load. The slight parasitic loss may very slightly cut down fuel economy under milder driving.
I definitely prefer to have LSD rather than not.
Jim Johnson
98 SVT
03 Escape Limited
Posts: 24 |
i would never call a LSD bulletproof Mazdaspeeds break, phantom grips break
2000 ZX2 S/R Zinc yellow
Posts: 21,197 |
Originally posted by ZX2 S/R: phantom grips break
Umm no $h!t! Because it's not an LSD! Basically a set of clips you install in your stock diff to "simulate" the effect of an LSD.
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 21,197 |
Originally posted by ZX2 S/R: i would never call a LSD bulletproof Mazdaspeeds break
Is it manufactured by Quaife or Torsen? Nope Tochigi Fuji Sangyo. Hence the issues. No one on here with either LSD has had one fail.
-'96 SE MTX 3L
