I have had a few posts here, over the past year, each one has predicted the end of my CD4E. Well, its been a year, and for the first time, I think I may believe it.
For the last couple of months the trans shifts softer (?) after about 10 miles of driving. From a stop the RPMs need to get a little higher to get the car moving. Nothing much, *maybe* a 200 hundred RPMs max.
Tonight was the Utah meet in SLC, about 60 miles from my house, mostly interstate travel. When I was about 5 miles from the meet, still on the freeway, it was like I clicked my e-brake on a couple of clicks. I felt like I was on flat ground, but the car downshifted/sped up then upshifted. It did this a few times until I met a bigger hill and it needed to downshift to go up the hill. Cruise was on at this time.
I get to the meet and am there for about a half hour when we decide to go get a bite to eat. Pulling out of the lot, I noticed that the RPMs did the few hundred climb to get moving. The trans had cooled considerably already so I thought it was strange but that was about the end of it. We got to the restraunt and were there for probably close to an hour.
Upon leaving the restraunt, I had a fairly substantial hill to climb to get back onto the road. I had slowed almost to a stop to make sure I wouldnt scrape. I got on the gas again, the RPMs climbed, almost freely, to 1500 then it engaged first and went. I kept doing this from a stop, but everything else was fine. I was watching my trans temp and it hadnt even reached 180F yet, ~10 miles from the restraunt. I stopped for fuel, and it did it again pulling out of the lot. Get up to speed and everything is good, as long as I dont stop.
About 2/3 of the way home, sub-interstate speeds, I notice that I now have a flashing O/D light. Trans temps havent broken 200F yet, mainly because of the speed I am moving. I did notice at one point in time, I was at 70 MPH and 2500 RPMS, so it would appear my overdrive was engaged even though the light was on.
Getting back into my city, I notice that I now have the dreaded bang-shift between 1,2,3, and overdrive is completely disengaged. I am keeping an eye on the temps and even though I am only doing about 40, Im at about 210F, which is perfectly normal for in town driving. I start climbing the hill to my house, where temps always raise, and I peaked at 230F as I parked it.
A couple of hours pass, the car has cooled so I go out to check it out. I start it up and the trans is at 100F, I pull out, noticing no late engagement in reverse. Put it in drive, lightly touch the throttle and the 1500 RPM engage is back. Its not a gentle slip into gear, its like I let the clutch out a fast but not enough to break the tires free. I had the car pulled back into first, the RPMS climb and I shift. It shifted hard enough that I damn near broke the front tires loose. I never got it going fast enough to make it into third. The car wouldnt have had a problem getting there, its 2am and I didnt want to go speeding around my neighborhood. The OD light is off at this time, and does come on going around the block.
From what I have read, it appears that my TSS would be the first place I want to look. None of the threads I have found have said anything about late engagement from a stop.
The trans has 136K. It has lead a slightly neglected life but it has gotten much better. It has a trans cooler and a remote filter installed (Baldwin B2-HPG). The last sample that was done on the old ATF, 9000 miles ago, showed high lead content, which they thought was gear marking compound, but all other wear metals were right in line with the average levels for a CD4E. Insolubles were at a trace levels. No moisture was present. The oil sample was performed when the ATF was completely changed. Im thinking that the trans isnt completely baked because the temp readings are the temp of the fluid exiting the trans. The late engagement scares me though.
Cliff notes: Late engagement from a stop, bang shifts, OD light (that is now off), reverse is good, OEM TSS. Temps never got extremely high.
