#107261 10/13/01 01:44 PM
Grunt Offline OP
Ok, I've used search and still haven't gotten a difinitave answer to what seems like an old question. What's the difference between the SVT and SE KKM intake and is the difference worth getting the SVT one for a SE?
This is my next mod as I have the resonator removed and looking to put in dual exhaust.
98.5 SE Sport - 5 speed
#107262 10/13/01 03:02 PM
E
E
I think it all has to do with where the IAC (Idle Air Contorl) valve is located. I think that is what it is called. Either way, if you look at the air box you will see a wire coming off of a sensor on the side of the box. It is only that way on the SE. The SVT has it on the rubber hose leading to the throttle body. So I believe the KKM for the SE has a hole for this, while the SVT does not.
Check the FAQ, I think there is a how to on how to swap a SVT for SE intake. Don't quote me on what that is called cause b/c that is an educated guess, but I am pretty sure that is the reason.
2000 SVT Contour - Silver # 1675/2150
svt1675@comcast.net
This Shine brought to you by the letter "Z" for Zaino
#107263 10/13/01 03:03 PM
I
I
Ok the Svt KKM intake wont work on the Se. There no differene in performance either. So stick with the Non-svt one. and for your Exhaust question if yo put 2 high flow Mufflers out back your car is going to Droon.
#107264 10/15/01 03:30 AM
The sensor is the Intake Air Temperature sensor (IAT) and as Eric mentions, the SVTs mount it upstream in the accordian hose. I believe the SVT KKM setup may have a better/different air coupling for the fenderwell because SVTs remove the intake resonator and might have a different opening. (You can mod the intake res on your SE...)
Scott
#107265 10/15/01 05:54 PM
I don't know what you mean the SVT KKM won't work...I've had mine for two years and it works just fine. The late Ray Mcnairy had one on his infamous "Sofia" and he said it worked just ducky. I humbly agree :-) The cold air does work if you get the crap out of the fender well. Never say "won't work" around here.......hehehehehe.....
-Rob cool
1999 SE Sport, Medium Steel Blue
(CEG member since 2/98)
SVT Dual Exhaust w/ Magnaflow res. and 3 1/2" SS Tips, E0 SVT Rims w/ Kumho 225/50ZR-16's, Superchip, SVT KKM, SVT Side Skirts, SVT front and rear bumpers, BNM white-faced gauges w/ blue glow, Carbon Fiber Shift Knob, no intake resonator, BAT Big Brake Kit C, Roger R dead pedal
*DEFINITE future mods, by 7/02*
wider rims, Y-pipe, revised exhaust, SVT TB, SVT Upper Intake w/ powder coating (GO BNM!)
#107266 10/15/01 09:48 PM
Personally I would have gone with the SVT KKM because of the cold air fender draw. But I didn't want to risk it wouldn't work. I don't see why it shouldn't -- the metal bracket that attaches to the MAF should be the same as is the filter. I think the filter cap is the only difference. confused
Dan Parmelee
1999 Acura Integra SiR-G coupe
"I heard Affleck was the bomb in Phantoms"
"Word, bitch! Phantoms like a muhfuka"
#107267 10/17/01 03:28 PM
F
F
Dan,
You are correct in assuming the MAF sizes are the same... I got the SVT kit for my SE, and while I have run into a slight snag with it, the SE MAF bolts up to the SVT adapter without any modification. Here are the snags I have run into which can be easily fixed, but will take some thinking as to exactly which way to fix them.
1. The silicone hose stops about 1/2" short of the fender duct. I either need to increase the distance between MAF and TB or obtain a longer piece of silicone hose for the end cap. I am assuming that the "accordian" style hose between MAF and TB are of different lengths, but since I do not have any owners of SVT's in my area, I have no visual way of comparing the two, but I can assume this to be true as BAT's catalog states that their revised intake tube will work with a stock SVT box, but will only work with an aftermarket filter on an SE, so I am assuming that the two differ (SVT is longer?)
2. I am having problems locating a good mounting spot for the support bracket, which is in essence a piece of metal bar with two holes drilled in it. This bracket will either need to be shortened and have the hole redrilled on one end, or a mounting location other than what I am looking directly at will need to be found.
3. IAT must be relocated.... if I go with an SVT MAF to TB hose, this will not be an issue, but is still something that the SVT kit does not have that the SE kit does due to the SVT's IAT already being relocated, whereas the SE IAT is in the airbox.
I know I can do this, and I am close to solving the big "mystery" (j/k), but right now with school and all I am at a stand still. However, thanks to input from Rob_B I have gotten closer to completion of this project than I would have on my own. I would drive the car as is, but I am still waiting on my Borla kit from Muscle Motors (3 weeks on backorder.... grrrr... hurry up Borla) and my stock exhaust including cat is off from underneath, and I am not putting it back on just to drive it to go on a wild goose chase just yet. But I will fill you guys in on things as I find out more.
BTW, for all of you who read my previous posts griping against KKM, I have not changed my stance, but they are unfortunately the only company to date that has come close to offering any type of CIA for this car, so I bit the bullet and bought one from them and simply told Warren this time that my car was an SVT. If you want true CIA, KKM is the way to go.
#107268 10/17/01 04:27 PM
I went with the SVT air cleaner, zip tube and inner fender adapter. No brackets to fabricate. I found an extra IAT and sensor plug, so I used it as an adapter to lenghten the IAT wiring harness. I removed the inner fender adapter and found no silencer. Everything dropped into place... sort of. It took about 30 minutes to change. One warning.. the zip tube from the SVT has a larger TB opening than the SE tube.. I just tightened it down. I still have the SVT MAF sitting on the shelf.
99 SE Sport..ATX
SVT exhaust
SVT zip tube and air cleaner assembly
Tinted windows
17" Cougar Zn Wheels
#107269 10/19/01 03:11 PM
Grunt Offline OP
This is good news, I think. Does anyone have pictures? I'm still stuck on the part about the mounting and the intake cap. I know what it looks like but not sure how to adapt it on a SE
#107270 10/20/01 02:06 AM
F
F
Grunt,
I am working on getting pictures and such out on the progress of my setup as I am doing the exact same thing you are wanting to. However, until my Borla kit arrives my car will be off the road, so maybe another week or two before I can get a dry run of this setup and run it through its paces. Until such time as I can prove it performance worthy, I do not want to send out pics of a setup that is a dud. So if nobody else posts before I do, check back within a week or so on this and I should have something up.
