Page 5 of 5 1 2 3 4 5
TronX Offline OP
Any luck with that socket problem?
I haven't tried again yet. I can't get a open ended wrench in there. The lobe of the wrench hits on some tubing right by the sensor and i have no room to turn it either. I'm just going to take a break on it for now. My guage hasn't worked for 2 years so I can wait a while longer.
TronX Offline OP
Wrench won't work.. I ran into the same tube. It's hard and does not feel like that part comes off very well. You need a small ratchet and deep long sockets to get around that part. Even still, I had to fiddle around until I could find enough room to move using 2 hands. Cut me up good.
TronX Offline OP
Hmmm.. does that metal heat shield above the manifold come off easy? That part was also in the way and might help give you a little more room.
why don't you guys just take the whole thermostat housing off?
How many Vs would a VTEC TEC if a VTEC could TEC Vs? The one, the only....FRNKNFORD http://www.westvalleycs.com
TronX Offline OP
Sounds like a lot of work for such a simple part Davis.
C'mon, if I can do it then I'm sure others can as well.
I mean since it's difficult to reach. The housing is only held on by three bolts. Just a suggestion really for anyone that searches in the future and finds this thread
i would take the whole housing off but wouldn't i most likely need a new gasket then? I would rather not have a working temp gauge then to have to do that sincei havn'et had one for 2 years.
TronX Offline OP
Yeah, your car is like mine in that it's old enough to come apart the more we mess around with it. I think you should try it again with a smaller ratchet and deep socket. Or you could just take the car someplace and have them put in the part for a small fee. My car didn't have one working for at least a year, but it sure is nice to know if my car is overheating with the hot summer coming up.
