I should have taken pictures because there are other people that will one day have the same problems as me..sorry guys.
1. You must move that big hose out of the way! This was by far the most hard part for me to get that hose off the water housing.. what a pain! Vise Grips might help, I used plyers.
2. You will only lose 1 cup of water removing the main hose. However, have the new part ready once you remove the old sensor because once this is taken out LOTS and LOTS of cooling fluid is going to poor all over the place! I was quick enough to plug the hole and put the new part in without loseing too much fluid. I added water just to be safe and will pickup some more Anti-freeze later.
3. Because of the downward angle it's a pain in the $%#$!
%!! I thought it would be easy, but I had a hard time getting down in there with all my tools. Using my O2 socket I was able to wrench it off and back on. The red marks on my hands and arms are starting to fade away..lol
4. This was a 1 1/2 hour job for me and that is counting the time to check, check and recheck and drive around and check again for leaks.
5. The end result is that the guage now moves to the (M) like it did years ago.
GP Sorensen TSU227
OE #F7CZ-BA; DOHC
Advance auto parts
10.88 + .82Tax = 11.70$
6. Make sure you have the right part. As you can see in this thread there are many types based on the year and the month. My car was made before 3/98 and the part was listed in the 97's and not the 98's. If you reach your hand down in there and feel a metal wire lock that you push in and the end pops off the sender then you have the part I was playing with that is flat and has tabs on the smaller sides. Other cars may find a whole other part that is much longer with another end that has one tab. So again, get the one that looks like it matches up in those pictures.
7. Having fixed this for such a little cost and with good results I can now move on to fixing other issues. For anyone that needs to have this fixed, good luck.
8. P.S. don't over tighten the sendor back on. I did find that because this is plastic housing you might strip. I had the feeling like it wanted to do this on me and stopped.
