#1069995 10/05/04 09:54 PM
i have a coolant leak on the passanger side of the motor in the front of the car. as close as i can tell it is coming from the cylinder# 1 exhaust gasket. has anyone seen a head gasket issue like this or is there a coolant line above that that i can't see. it isn't the lower rad hose. like i said the highest point seems to be the exhaust manifold. but no bubbles and no creamy oil. in fact there hasn't been any running issues. i pulled the plug, it was the right color and the piston was dry. this was while i was pressure testing it. i thought maybe someone who has had the motor out, may have had a better look at that are of the motor. thanks.
#1069996 10/05/04 09:57 PM
H
H
4 or 6 cylinder ?????
#1069997 10/06/04 11:56 AM
sorry about that 96 v6 automatic.
#1069998 10/07/04 09:46 PM
anybody have any ideas? maybe this should be in duratec maintenance?
#1069999 10/07/04 11:36 PM
Well I also have a 96 - mine is a 4cyl though and I had the same problem actually. It leaked for about a period of 3-4 days and stopped just as mysteriously as it began. I had it looked at while it was leaking and they couldn't find any areas of trouble at all. It's been find now for almost 3 weeks.
'96 Contour GL T-Red Finally with pictures! http://www.cardomain.com/ride/2059584
#1070000 10/08/04 01:57 AM
Check for pin holes in the mettle coolant pipe that runs across the engine (left to right) it is likely rotted.
jeff
have you fixed your ford lately?
