#1068811 10/04/04 03:10 PM
9
99REDSE Offline OP
okay first off.. the car was in a slight wreck a bit ago... waiting to fix it..
the front core support is slighly on the radiator...
was fine, but now, for a week or so i see water\greeze anitfeeze dripping from front of engine... i can see it on the the lower part of frame, in front...
the car temp goes to normal quick, but nothing further... at times the cars fans are constaly running...
so this morning... its chilly out, a 10 min drive, i had the heat on full blast, and no heat... at the end of the drive i could feel it get warm, then cool, it got pretty hot for a min then back to cool...???
1999 T-Red Contour SE Sport S&B Filter Custom 2.25 exhaust with magnaflow parts. Focus 16" Rims
#1068812 10/04/04 05:04 PM
9
99REDSE Offline OP
oh no... sounds like WP!
1 question... when my car is getting fixed. the guy is taking off the front bumper and radiator... is the WP easy to reach if these are off?
#1068813 10/04/04 05:34 PM
you do not need to remove either to get to the water pump, just the battery
but if I read your post right there is other damage from an aciedent around the radiator? if so then that would make sense to take the radiator and bumper off/out
#1068814 10/04/04 07:21 PM
Your lack of heat from the heater could be from a bad water pump due to the impeller that fell apart.
It could also be from the coolant being too low to circulate into the heater.
#1068815 10/05/04 01:21 AM
He probably didn't replace the antifreeze that leaked out.
Can't get heat from air (or engine cooling, either) on this car.
Steve
#1068816 10/05/04 08:42 PM
9
99REDSE Offline OP
exactly.... THERE WAS NO ANTIFEEZE IN THE CONTAINER!
it was bone dry!, the car never overheated thou, but the fan was always running etc...
got some prestone, filled her up.. and wham! hot air! wooohooo... and looked the leak... coming from rad... WP area looks dry...
