Posts: 540 |
No problem - it's always good to get opinions from others who may have dabbled with this before. I plan on having a lot of fun at IRP - can't wait. Just hope I bring the car home in one piece -lol.
'98 SVT Red/midnight blue - a few mods
E0 wheels for sale - PM me
b0x @dm1n
b0x @dm1n
Posts: 4,397 |
First off Read the FAQ!
Second there is nothing wrong with using synthetic fluid but do not switch to silicon fluid(Dot 5). Switching to Synthetic brake fluid is like switch to synthetic oil, probably better for you in the long run. But Silicon is completely different and is only used in special braking systems.
-Andy
Andy W.
The problem with America is stupidity.
I'm not saying there should be a capital punishment
for stupidity, but why don't we just take the safety
labels off of everything and let the problem solve itself?
Posts: 540 |
Actually, I did read the FAQ - first thing I checked. I also checked other sources, hence the contradictory information I found. Your source (the SHO Times) conflicts with other data I found. I was simply trying to find someone who had done this (which the FAQ did not address) and any problems associated while changing from DOT3 to DOT4 (which the FAQ also does not address). Next time maybe I should just talk to Ford first, rather than checking the FAQ's that don't answer my questions.
b0x @dm1n
b0x @dm1n
Posts: 4,397 |
The common problem is that people get silicon based brakes fluids and synthetic based mixed up. Where do you see a contradiction?
The DOT 2 spec is for drum brakes and is obsolete. If you have any DOT 2 in your garage, throw it away! DOT 5 is for silicone brake fluid. Silicone brake fluid (DOT 5) should be avoided because it is not compatible with regular brake fluid, it is hard to pour without introducing bubbles and thus results in soft pedal feel, and moisture still gets into your system and will pool in low areas like your calipers and encourage rapid corrosion. STAY AWAY!
That leaves DOT 3 and DOT 4 fluids. These fluids are compatible with each other and may be interchanged or mixed with no ill effects.
-Andy
Andy W.
Posts: 4,693 |
If you are asking for long term use of DOT 4 fluid and if it had any ill effests I'm an example.
I change brake fluid annually. I have used DOT 4 fluid since the first change when the car was one year old. I have had no hydrauilic brake or clutch system issues. The car was purchased in August of 97 and has just gone over 200,000 miles. Most of the time that has been with Valvoline Synpower brake fluid.
So it seems to be working fine on my 98 SVT E0.
Jim Johnson
98 SVT
03 Escape Limited
Posts: 540 |
My original post had nothing to do with silicone based fluids - simply DOT3 vs DOT4 (neither of which I have found use silicone). In my second post I believe I stated Ford said do not use silicone (which I am not). The contradiction was the SHO Times article (from the FAQ section) stated that "DOT3 and DOT4 fluid can be interchanged with no ill effects". An article supplied by another CEG'er some months ago stated that changing from DOT3 to DOT4 was not recommended. So, which one do you believe? I believe the SHO article now because I asked Ford SVTOA and they said it was OK. I think we've beat this one to death, don't you think?
Posts: 540 |
Thank you - since I have the same year and model as you I feel much better about this.
b0x @dm1n
b0x @dm1n
Posts: 4,397 |
Now that I've scanned that article, I see what you mean. But in the second section, he contradicts himself within 30 lines. I think they state "be careful" just to cover their ass. Many CEGers have run all ranges of the Fluids listed in the FAQ and have not noted any leakage problems or damage. I personally prefer ATE's fluids but the Synpower is good stuf for the less agressive driver. I've been running ATE for two years now.
-Andy
Andy W.
Posts: 540 |
One of my SVT friends did some research and he suggested the Ford DOT4 stuff, which is what I purchased. We'll find out how good it is this weekend. I guess my initial question was 100% clear on what I was looking for, but I think I have the answer now.
Posts: 4,639 |
and the ate is super easy to use. i knew exactly when the old stuff is out cuz the blue starting flowing out. then get the regular ate next time and bleed out the blue stuff.
Hugo AIM:omegazodiac
