Page 2 of 2 1 2
W
W
Originally posted by SVT 065 G:
My friend charles (96 gti vr6) used this web page to make his intake and it turned at awesome so I thought I would share. Its a well detailed and thought out page:
http://www.teamdelsol.com/howto/coldair/diycoldair.htm
Pretty detailed, a good find.
Keep up the good work.
warmonger
You can call me anything you like as long as it's nice.(all lies accepted)
99 Silver Frost SVT. #226 of 2760
Engine: 3.0 power!
Unique Stuff: Sunroof control module (#1 of 9)
Car Audio: Loaded and loud!
Check them out at
http://home.earthlink.net/~twilson1726
ABS is a much better choice than PVC. Its still a gamble though, as its softening point is around 80 deg. celcius, which would be possible to attain near the engine (I got 63 deg IAT from idling 10 minutes in the driveway...)
I'm still debating whether I could mack a BAT pipe mock up out of ABS. I'll probably chicken out and use aluminized steel, with ceramic paint.
Marco Tatta
98.5 SE MTX, Duratec
EGR block, fog light
fix, custom shift boot, monsterflow intake, Ecotek valve
Quasi dual cardoctor exhaust.
Hacksaw short shift, Momo race "s" carbon knob, ghetto rear strut bar, 16 inch cougar wheels with 225/50/16 kumho 712s
OK, here's another option- pull the rubber mounting ring out of your conical filter and bolt it directly to your maf. drill a 1/2" hole in the backside of the filters ring for installing the (non svt) IAT. May be hard to see in this pic, but the MAF bolts directly to the filter.
4 bolts are threaded through 7/32" holes in back of filter which line up with MAF holes. Spin off 4 nuts to remove and clean the filter. The IAT slips into a rubber grommet on the bottom side of backing ring.
Scott
How about using ABS plastic pipe instead of PVC??
Originally posted by 99SVTguy:
You can't do that....When PVC heats up beyond normal operating range, it give off fumes that will cause all kinds of problems and destroy your cats. Trust me, I found that out the hard way on my old T-Bird. PVC is not an option. You can have the metal intake coated with foam insulation (like the Iceman Intake) or Jet-Hot Coated or something.
Andrew
99 SVT
Page 2 of 2 1 2
