Page 2 of 4 1 2 3 4
Originally posted by Frank:
To that list you can add Brad Noon (spun rod bearing... duh) and a Cougar guy, everlast66 (243hp, blown motor)
what happened, what was the details of the cougar guys blown motor?????
www.shox.com Dealer
Koni's 135 a piece
Eibach's 190 a set
KYB's 70 a piece
H+R's 225 a set
see profile for website, aol name, etc
Business:WestEndMobil@yahoo.com
Personal:Corey_pimp1@yahoo.com
1998.5 SCSVT ($16000 takes it)
2001 GSXR-1000
1988 Corsica (the beater)
yep !!! smile
Sam
1998 Contour SVT #180
1/4=14.2 @ 101.17MPH
AOL users = PhatSVT
_ _ _____________ _ _
1986 Mustang GT
12 second club
W
W
I was only going by the dyno plot I have, sorry Sam, I will change it.
-Mark
You can do something for Love...
You can do something for Money...
But there is nothing quite so satisfying as doing something out of Spite.
GTExtreme1@aol.com
Can be blamed on oil starvation or cavitation. Running 120 MPH plus for several minutes, a few blasts to 130-140, then severe nose over when it spun. Most likely I did not have the oil drain back line at a high enough angle to get the oil back to the pan quick enough from the SC. I had a small oil leak too (drain back connection at the pan), but was still over full (6 quarts) at the time of the failure. Thinking the extra in the SC and return line acted much like the SVT oil cooler in slowing down the return flow. Should have run a little more angle and a little more oil.
Shoulda coulda woulda...
Brad Noon
'99 SE MTX
3 point oh my God H.O. 179HP/178TQ
BNMotorsports Floormats, powder coating, TB optimizing, Gutted cats, etc
BNMotorsports is now the preferred distributor of Contour/SVT/Mystique Indiglo style gauges!!!
bnmotorsports@msn.com
IIRC the Cougar guys problems came about because the person he had to do the tuning on his car, adjusted the cam timing with the sprockets on the car and got things too far off...so he bent all of his valves among other things....
Nikolas
1999 Mercury Cougar V6
KKM Intake,SVT TB, SVT Upper/Lower, 19lb injectors, Diablo Chip, MSDS Headers, Custom Exhaust, B&M Short Shifter, Progress Lowering Springs, 18" Axis TC's, OMP Strut Bar, AAM 24mm Rear Sway Bar, Koni Struts
15.09 @ 91.54(corrected, pre-SVT conversion, DiabloChip, and Injectors)
Originally posted by I-Dom-In-8:
I would have to agree. Its also Cheaper as well. If you know someone or know how to drop it in
The 3.0L costs an arm and a leg to get put in. It's cheaper in the end to get a S/C.
Auvie Kincer II
99 SVT Contour
T-Red
#1254 of 2760
Born on 2/25/99
Mark its all good doesnt bother me. debating on selling the car now though. need V8 power with supercharger.
Sam
AOL users = PhatSVT
1986 Mustang GT
12 second club
What is the word on the people that sent the s/c back to vortech?
Are they just sending another one back or are the "re-engineering" it?
joshua_drew@hotmail.com
AIM "nerdsalot2"
1998.5 Black Contour SVT
1998 ZJ Limited 4.0L AWD
My SC cost me $3,1XX including battery relocation, try to get that deal again. Installed by myself. Installation would have cost me an hourly rate for a minimum of 12 hours (per Vortech install sheet, ya, right, more like 20 hours) at $65 per hour = $780-$1300
Total of $3880-$4100
My 3 liter cost less than $800 rebuilt ($525 delivered full engine assembly, $125 for gaskets rings and mains are another $125 which I didn't need), installed by myself. Ford gets in the neighborhood of 12 hours for the engine transplant. $66 per hour = $792 plus tax, 4 hours to swap over your old engine parts if you rebuild the 3 liter short block yourself = $264, 6 hours to disassemble and reassemble 3 liter if they do it = $396
Total = $1963 installed and rebuilt at a Ford dealership.
It adds up the other way around.. Add some knowhow in there and save a bundle on each, but the parts are still much cheaper than the SC way. Not as much HP as the SC though... wink
Brad Noon
'99 SE MTX
W
W
Vortech has had my SC for a couple weeks now and they haven't even opened the box that i sent it in...
-Mark
GTExtreme1@aol.com
Page 2 of 4 1 2 3 4
