Page 2 of 2 1 2
All the return type injectors are side feed ,the later are top feed.I'll dig up some nath on matcing etc injector size Vs HP etc.
V6 MTX
'Its only nuts & bolts!'
Haines Motor Sports Inc,
IMO putting the large 34/35mm lower on the tiny stock upper may lose power.
Seems like the added turbulence caused from going from "maybe" 28mm (stock upper) to 34/35mm back to 28mm (heads) would do a number on velocity. Among other things...
You are much better off getting the upper! It's already smaller then the stock lower...
2000 SVT #674 - Check it out!
Clear something up for me - is the only thing that makes the lower returnless the fuel rail? Or is there a physical difference in the casting or injector type.
Will the 98 (E0) fuel rail and injectors fit on the 2K larger lower?
I think I already answed that question about 4 posts up. Someone needs to try it to find out. Do you want to be a pioneer?
Jim Johnson
98 SVT
I'm about to have my hands on a 3.0L lower, and yes I'm going to try.
Side feed(early) Vs top feed(returnless) injectors.
V6 MTX
Page 2 of 2 1 2
