Well I do plan to replace my struts and spring around all four corners but I must get this basic maintenance done first. You know fix what is currently broke. Once done I will then ugrade. This has been a real tuff year for me and the tour.
1)alternator failed
2)o2 sensors had to be replaced'
3)axles replace because boot torn during alternator replacement
4)VSS sensor broke as well as speedo cable and took a week to find correct part but thank goodness it was not an atx failure.
5)replaced all mounts except the engine mount.
6) replaced one front brake assembly, bracket and caliper
the car needs a
1) new alarm for after a lightling strike it really started to act funny
2) head unit needs to be replaced
3) mentioned struts and springs
4) carpet on the floor needs to be resecured and/or amp wirings need to be redone so that carpet will fit properly
5) window weather stripping needs to be replaced on all four windows
6) steering bushings and end links may be replaced to firm up steering input response.
7) one of the plastic moldings on the c-piller (behind the rear window of the passenger side behind the driver next to the rear windshield has had one of its plastic connecting tabs worn away from removal one to many times that it no longer properly stays in place
8) cigarette lighter no longer works and so cannot use any 12volt acessories currently.
9) my six inch sub in a sealed 6X9 inch box now is making cracking noise but still produces enough bass for my tastes and so I might purchase a new 6.5 inch driver from adire "The Extremis 6 - the ultimate 8 Ohm midrange/midwoofer driver"
10)one of the cup holders is broken and so the hold unit needs to be replaced.
11) those things that have not yet failed but will in the future before 1-10 get taken care of.
12) the driver side rear view mirror makes a high pitched squeaking noise the going over bumps and needs to be oiled I guess
those are the list of things to fix in the up coming year
I know, I know why not just buy a new car? Well there is the issue of increased insurance, a car note, the car is now kept on the street due to a lack of parking, the car is driven daily now, there will be a new drive in the house, parts are still available for this car and so why not just keep it running, the tour is not a high theft car, I enjoy driving the car, and I get some sort of sick pleasure out of attending the car's needs. Go figure
