Originally posted by FAQ: Left Front <Adjustment> Right Front -1.8 to 0.7 Camber -1.8 to 0.7 1.4 to 3.4 Caster 1.4 to 3.4 -0.17 to 0.00 Toe -0.17 yo 0.00 Cross Camber -0.7 to 0.7 Cross Caster -1.0 to 1.0 Total Toe -0.34 to 0.00 Left Rear <Adjustment> Right Rear -1.5 to 0.5 Camber -1.5 to 0.5 0.04 to 0.24 Toe 0.04 to 0.24
VS
Originally posted by Ford: Left Front <Adjustment> Right Front -1.7 to 0.8 Camber -1.7 to 0.8 1.3 to 3.3 Caster 1.3 to 3.3 -0.09 to 0.00 Toe -0.09 to 0.00 Cross Camber -0.7 to 0.7 Cross Caster -1.0 to 1.0 Total Toe -0.17 to 0.00 Left Rear <Adjustment> Right Rear -1.4 to 0.6 Camber -1.4 to 0.6 0.02 to 0.12 Toe 0.02 to 0.12 Total Toe 0.04 to 0.24
top reason why I brought this up: it is common knowledge here that toe should be set as close to zero as possible (on the negative side for the front; on the positive side for the rear) the table above is taken from Ford alignment stand and it is not substantially different from the one printed in FAQ other than the toe range which is cut in half in good direction.
This is what I had vs what I have now (98 SE w/ BAT kit): Left Front <Adjustment> Right Front before/after before/after -1.0/1.1 Camber -0.9/-0.9 1.6/1.6 Caster 2.4/2.4 -0.41/-0.05 Toe -0.39/-0.04 Total Toe -0.80/-0.01 Left Rear <Adjustment> Right Rear -0.4/-0.5 Camber -0.9/-0.9 0.10/0.08 Toe -0.06/0.07 Total Toe 0.04/0.15
