Posts: 70 |
I am having trouble finding a spot to mount my side neons on my car. There is an undercarriage protector in the way and I don't want to mount it on the protector because that would make it the lowest part on the side. Also, I don't want the actual neons visable. Is there a way around this? I have a '99 SE.
(I know; a little dirty.)
Posts: 5,143 |
get the SE skirts and mout the lights to the inside of the skirt... Thats the only way I can think of it working without it looking like junk.
Edit: try not to post the same topic in two different boards.
98 Corolla LE 1.8L DOHC 1ZZFE
TEIN H.Tech Springs
Tokico HP series Struts
Short ram air intake
Tsudo Axel Back Exhaust
Posts: 26 |
Like AliasJerk said, get the SE Skirts. That's the only way around not having them show. I got the skirts and mounted them in the inside of the metal beam. If you need a picture, I can get one for you.
Posts: 70 |
Where do I get the skirts and how much do they cost? Could you post of picture of your skirts?
Posts: 70 |
I am not looking for anything fancy, just something cheap.
Posts: 6,791 |
DRill 3 holes on the left and right body crease, it's as simple as that! Use zip ties, it may sound ghetto but they'll probably never fail.
Posts: 1,074 |
Originally posted by thekep: Like AliasJerk said, get the SE Skirts. That's the only way around not having them show. I got the skirts and mounted them in the inside of the metal beam. If you need a picture, I can get one for you.
hey can you take a picture and post it, cuase ive been thinking aobut getting neons, just curious how the install goes. I was just going to have dean do it but if its not hard maybe ill do it myself.
Brett
The man thinks its best for everyones safty if i dont drive for 6 months
'95 Moonlight Blue Contour (ITS ALIVE AGAIN!)
MODS:
Knauberized,Reverse Indiglo Gauges,LED's,AEM Intake,Rust holes for more power!
Posts: 70 |
Originally posted by RawBurt: DRill 3 holes on the left and right body crease, it's as simple as that! Use zip ties, it may sound ghetto but they'll probably never fail.
I don't like that because then the actual neon tubes will be visible from the road, and I want just the glow visable. That is why I want to mount it behind a side skirt.
Posts: 6,791 |
If you have side skirts then the actual tube will not be visible.
Posts: 70 |
Originally posted by RawBurt: If you have side skirts then the actual tube will not be visible.
Ok, I thought you were giving me that tip as an alternative to getting side skirts. Anyone know where to get some? I just want the cheapest thing I can find that will fit.
