Page 2 of 2 1 2
0
i can dig it. looking good man.
-2000 csvt silver frost #1619 -magnaflow 14415 -optimized T/B & y-pipe -superchips xgt1 -75mm proflow maf -K&N RU-3530 -fsvt smart pump # 354Z-9H307-BC -spec stage one, LSD -low-tek,a/f,oil press.,volts -B&M short shifter -17" konig gt-r
Nice, when you get them balanced next, take it somewhere else and see if they can leave that weight and place other weights on the inside of the wheel (where they should be anyways). I know they're not supposed to leave the weight, but if they can do it, then why not?
Looks really good. Im thinking of black wheels on my tropic SVT.
-tropictour
2000 Contour SVT Tropic Green SHO Shop CAI Bassani 1999 Contour SE BAT Kit
1
Looks good... I had the exact same thing done with my black svt... I used graphite high performance wheel coating drom dupli-color... lots of prep work, i also have the red calipers. Its a great combo
98 CSVT Black/Blue #135 of 6535 Formerly known as "SVTbullet"
N
N
For the balancing problem, I think that should had remove the outer weight, do the paint job and have your mags balcance in what we call static balancing. With this procedure you nly but weight on the inner side of the mag and you won't have vibration, or slightly. You can also have clued weight inside the mag.
Nic.
Contour 99 MTX V6 fully loaded, stock with 110000km. Illuminated sunroof switch. About to do the mystique rear dome light conversion with eyeball dome light.
I
I
that should be an ad for McDonald's cuz......im lovin' it!
E1 CSVT s/c-----x turbo---x 3L------check
Page 2 of 2 1 2
Moderated by  1314_dup1
