Posts: 160 |
Originally posted by emartinez13: ... The temp sender on a 4cyl is located on the underside of the thermostat housing which is bolted to the head...should be easy to identify.
That's where I would start. Check the plug that connects to the temp sender. For location see quote above. I just fixed mine yesterday and the plug on mine is all busted up but I managed to connect it back in and now it's working again.
95 Gl Zetec Atx
