Posts: 1,859 |
Originally posted by clocking: Whats it like trying to cut throw carbon fiber ? ? scares the SH$T out of me
With a dremel, like butter, realy.
'99 Silver svt
For sale
19" Axis Neo wheels
3.0 parts, pre-98 trunk,
Check classifieds
bp.powell@comcast.net
Posts: 3,840 |
I wouldn't even give it a 3. I can't stand the cowl hoods. Gaps with that amount of money too.  Anyway, for what it's worth, I hope you come up with a fix.
Troll. 1997 VW Jetta MkIII GLS 5spd
All hail my appearance on CEG!
Posts: 2,975 |
Quite a Bold entrance to CEG!
CF Hood and what looks like a wild trim design.
But thinking of selling the thing already!
Welcome
Let's see the rest of the car, it looks promising
1992 Ford Escort LX-E
-Tracer LTS spoiler
-GT Grille
Posts: 5,882 |
man, i was practically sold on that hood. i had one on my 98 accord and it fit like a factory hood. this one looks great but i dont want to have to fiddle wit da fenders. i wish you good luck and i think for your cost of investment and how good it looks you should definitely try to get it right.
Posts: 660 |
Originally posted by clocking: 1 other thing i didnt like was the dip in it
You pay $570 for something and then you decide you don't like the style?
Hey Tubs, I just lost my jengajam.
Your ghetto pass has been revoked. You're no longer an honorary brother.
Posts: 3,570 |
Posts: 9,872 |
Originally posted by rkneeshaw3.0: cawlk it!
Posts: 10,015 |
I have a huge gap on the drivers siode too, but I need to adjust it better, AND I'm, taking off the hood lift struts as they aren't required anymore and just cause you to flex the hood when you go to close it. I need to tweak the fenders too. All the same I think the hood is sharp and I wouldn't go back.
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
Posts: 1,423 |
Originally posted by SVT PETE: I've examined the hood on an SVT very closely.
The hood is about 1/2" too short from front to back and about 1/4" - 1/2" too narrow.
If you pull the hood forward to line it up correctly with the oval and headlights, it doesn't line up at all by the cowl. And vice-versa. You just have to find a "middle ground".
The width can be "fixed" by adjusting your fenders.
Unfortuantely, when a mold is used, it's tough to get it exactly right.
Pete is speaking of my car...my OEM hood fit perfect front to back and side to side. My gaps were very small and even, now they are huge. The biggest gaps are front to back and definitely the worst. If I line the back edge of the hood up with the end of the fender curve like the OEM hood was it is about 1" from the oval in the front. The rubber gasket on the oval has about a 1/4" gap between it and the edge of the hood If I move it forward the ruber seal in the back is not touching the hood. The hood is definitely shorter then the OEM hood by at least 1/2" maybe even more. The side gaps can be reduced by moving the fenders a little but front to back it looks like you are screwed. If I decide to paint my hood it will look like crap because the gaps will look gigantic...unpainted they don't stand out as much. I'm with everyone else on the reverse dip/scoop when they say it would look much better without it but I will live with it. I like the hood but am not real happy at all with the fit to say the least. Also some smaler items...the latch is not S/S so it is rusting along with the Black non-coated bolts supplied with the hood as well. The back where the cowl opening is not finished or supported and has quite a bit of flex and alsohas exposed raw fiberglass that looks bad.
My hood was 2nd on the list...
Scott
Scott
2000 Contour SVT #1464
Mustang Dyno: 171.6hp/145.3lb
Dynojet Dyno: 171.1hp/148.9lb
1989 20th Anniversary Turbo T/A "Indy 500 Pace Car"
#1376 of 1550 All Original, 46k with a few mods
2002 F150 SuperCrew
Posts: 6,760 |
*rethinks about a possible purchase in the future...
Ryan
Trollin!
