CV6MTX Offline OP
I emailed a clutch maker...don't worry who...they custom make clutches for any car, and performance set up...They asked me for some info on the stock clutch, and I don't know...here's what they need:
Could you give us the dimensions of the clutch disc, please?
Outside diameter and spline size.
And what is the engine size?
Engine size I obviously know...what's the clutch info...I need it asap...so i can get the info out, and get a price...Thanks alot
1995 Probe GT ATX TOO MANY MODS
1999 Cougar V6 MTX
Stage 1: (Basic Mods)B&M STS, Bassani Exhaust, KKM intake w/ weapon R pipe, ProFlow 75mm MAF w/optimiser, YoDude Y-pipe w/hi flow cat, SVT TB, SVT Upper IM, OMP FSTB,AF gauge, Aerogear fiberglass hood (completed)
Stage 2: (Top End Work) 19-24lb injectors, P&P heads w larger valves and HPC coated, P&P and port matched lower intake manifold also HPC coated, custom ground cams, Ford Racing 9mm wires, Bosch +4 plugs, Custom burned PAC or Diablo chip (will dyno with both), Apexi SAFC (In Progress)
Stage 3: (Transmission) Quaife LSD, CM stage 3 Clutch, Fidanza flywheel (In progress)
Stage 4: (Suspension)Koni adjustibles, H&R springs, Progress 21mm rear anti sway bar (Installing on Tues)
Current dyno: 172.9 whp with just bolt ons and stock exhaust manifolds (not gutted), oh, and bad wires smile...
Why not just look to Clutch Masters or Centerforce for a clutch, as they both have listings for the Contour V6?
dion
98 SVT with some mods
http://communities.msn.com/contourstuff
CV6MTX Offline OP
I know what clutches are available...
there's a Clutchmaster stage 1 and 3 available, a Centerforce dual friction, and an Unorthodox stage 1 and 1+, along with OEM clutches...
I still need this info...would it be bad to have another available clutch for the cougar/contour?? I think not. Have you seen the prices for the CM stage 3 and the UO stage 1 and 1+?? $585-$675....
1999 Cougar V6 MTX
