Page 2 of 7 1 2 3 4 5 6 7
#105926 09/25/01 03:01 PM
Yep, with the 3.0, which I now know needs some serious tuning.
Open manifolds: imagine an exhaust system that ends BEFORE the cat in the SHO Shop y-pipe.
There is a really huge post detailing my day at the track in the dyno forum, if you are interested. Look for "Set to dyno the 3.0" and go to the second page.
#105927 09/25/01 05:45 PM
He as Quaife and supposedly slicks on order! This past week the weather has been really cool in kc. He told me he was pushing 10psi of boost to 7K!!! The track he ran at is a slow and traction limited piece of junk. You either get a good run or your running 14.8's to 15.3 with the huffer smile or was I not to say that laugh
Originally posted by EPBurn:
Damn, assuming driver equality, that supercharger gives you a full second Phat. Impressive.
Merlin
281hp 324tq
Timing 14' FP 36,24lbs,190lph,75Maf,65tb,cobra upper&lower,B303, GT-40 Crate with X al heads, Mac shorties, Off Road H,2chamber Flow's dumped, Tokico 5wys, Hotichkis Ctrl Arms, Alum Drive shaft, 3.73, Sub Frame,Steeda Tri-Ax, 94 Seats Drivers side powered.
#105928 09/25/01 06:11 PM
See Sig
- 1996 Mystique Spree 2.0 ATX
- 2002 Mustang GT 5-speed
- North Georgia Auto Forums
#105929 09/25/01 06:20 PM
JVT Offline
detonated/pinged my way to a 15.08 @ 93.81
John
'98 SVT - modded
-15.01@91.8
'95 Suzuki GS500E
-faster than the above
---wanting a Speed Triple or Superhawk badly
#105930 09/25/01 06:49 PM
Only ran it once.
98 SVT
Black w/ Midnight Blue
Stock Rims
Sparco Pedals
Removed Resonator
TH Fix
Superwhite Bulbs
B&M Shifter
K&N Filter
KVR Cross-drilled rotors (front)
KVR Pads (front/back)
Aeroquip Steel brake lines (front)
#4248 of 6535 built
15.574 @ 88.35mph
15.814 @ 86.62mph
#105931 09/25/01 06:56 PM
15.2 @ 93.6 with a 2.596 60' time.
next time i'll be lowering the air pressure.
i used to be able to get 2.3s easily, had a 2.2 once.
hrmm. 14's will be here one day. smile
#105932 09/25/01 08:35 PM
15.1 @ 92
2.35 60'
KCIR 95D 80%
Waiting for some cooler weather...
2000 SVT #674 - Check it out!
#105933 09/26/01 01:26 AM
15.1 @ 90.72 MPH.
1991 GVR4
Lots of mods done.
#105934 09/26/01 01:45 AM
in the sig
Patrick
2000 SVT Contour #762
Silver/Midnight Blue
Built 12/7/99
K&N
15.29 @ 91.66 MPH
#105935 09/26/01 01:46 AM
15.54, got it this weekend with a 60' of 2.26 and a RT of .574. Still baffled by this. Also with Borla and MSDS (another baffled thought) Headers and nothing else. MPH was 88 and some change.
You guys running mid-low 15's stock are you on factory rims and tires? Wondering if my 17's are hurting the top end but improving the 60'?? Thoughts on this ????
