Posts: 3,419 |
Yep, with the 3.0, which I now know needs some serious tuning. Open manifolds: imagine an exhaust system that ends BEFORE the cat in the SHO Shop y-pipe.
There is a really huge post detailing my day at the track in the dyno forum, if you are interested. Look for "Set to dyno the 3.0" and go to the second page.
Posts: 2,631 |
He as Quaife and supposedly slicks on order! This past week the weather has been really cool in kc. He told me he was pushing 10psi of boost to 7K!!! The track he ran at is a slow and traction limited piece of junk. You either get a good run or your running 14.8's to 15.3 with the huffer  or was I not to say that Originally posted by EPBurn: Damn, assuming driver equality, that supercharger gives you a full second Phat. Impressive.
Merlin
281hp 324tq Timing 14' FP 36,24lbs,190lph,75Maf,65tb,cobra upper&lower,B303, GT-40 Crate with X al heads, Mac shorties, Off Road H,2chamber Flow's dumped, Tokico 5wys, Hotichkis Ctrl Arms, Alum Drive shaft, 3.73, Sub Frame,Steeda Tri-Ax, 94 Seats Drivers side powered.
Posts: 647 |
Posts: 4,042 |
detonated/pinged my way to a 15.08 @ 93.81
John
Posts: 148 |
98 SVT Black w/ Midnight Blue Stock Rims Sparco Pedals Removed Resonator TH Fix Superwhite Bulbs B&M Shifter K&N Filter KVR Cross-drilled rotors (front) KVR Pads (front/back) Aeroquip Steel brake lines (front) #4248 of 6535 built 15.574 @ 88.35mph 15.814 @ 86.62mph
Posts: 1,038 |
15.2 @ 93.6 with a 2.596 60' time. next time i'll be lowering the air pressure. i used to be able to get 2.3s easily, had a 2.2 once. hrmm. 14's will be here one day.
Posts: 7,329 |
15.1 @ 92 2.35 60'
KCIR 95D 80%
Waiting for some cooler weather...
Posts: 4,319 |
1991 GVR4 Lots of mods done.
Posts: 397 |
Patrick 2000 SVT Contour #762 Silver/Midnight Blue Built 12/7/99 K&N 15.29 @ 91.66 MPH
Posts: 1,447 |
15.54, got it this weekend with a 60' of 2.26 and a RT of .574. Still baffled by this. Also with Borla and MSDS (another baffled thought) Headers and nothing else. MPH was 88 and some change.
You guys running mid-low 15's stock are you on factory rims and tires? Wondering if my 17's are hurting the top end but improving the 60'?? Thoughts on this ????
