alexey Offline OP
HI guys.. havnt posted in a long time but I'm still loving the tour' ... now to the point..
The other day i thought I dropped my tranny cause i had no gears.... upon furhter inspection the tech at my work showed me what was up. The Upper right (view from under the hood) engine mount bolt sheared in half!!! That caused a small bolt inside the linkage to snap as well.. now we got a hold of a part number for the small bolt but the motor mount bolt is not sold seperately from ford.. only with the mount assembly... does anyone have the EXACT specs for that bolt? I need my car back ASAP!!!! thanks alot
Lexus ES300
alexey Offline OP
someone PLEASE!!
Lexus ES300
alexey Offline OP
Originally posted by alexey:
someone PLEASE!!
noone eh
Lexus ES300
well if the bolt sheared off you are going to have to get the rest of the bolt out before it can be replaced. so I am sure there is enough bolt left to measure it to find out with it is
I am more then certain it is meteric, to measure take the diameter and that is the first number and then measure the distance between ten threads, then move the decimal left one spot, that is the second number the pitch
so as an example M10x1.5 is a 10mm diameter bolt with a 1.5mm pitch and then you just pick the length that you need
alexey Offline OP
well my mechanic had to drill half of it out... cause he thought for sure it'b an easy find... i gave half the bolt here with me.. i think i'll just get various lenghts at the store
Lexus ES300
hit a junkyard. I see no reason why the bolts should be different for any year/trip countours.
T.
