What about that new water cooling for computers??? Will that work???
Im just kiddin, but seriously,finding someway to remove heat from the box is a great thing!!!
But htinking about it im not sure if it would work....cause in a CPU tower you have a fan blowing the air out, which promotes movement of the heat comming of the heat sink to get dran out, also lowering temps in the case.
Our engines are so cramped and warm with the heat resonating form the block, it would probably do no good to put a heat sink....might make it worse, since copper is a great conductor of heat also.....maybe look at the underhood temp comapried to the IMRC's actualtemp...if the underhood temp is hotter, then it might not be worth it.
Lupe
