Posts: 3,506 |
125,000 with no problems...but id still like a way to get heat away from it...but it probably won;t happy with out reclocation from the head.
being so close to the engine theres no good way to get the heat away form hit....Oh and a KKM is properly efective with a heat sheild.....with out that, you would be just sucking in hot air,(heat soak) which can cause low end performance loss. High end you do not need to worrie as much becuase your getting the flowing air while in motion.
Lupe
Posts: 5,975 |
Something that could help was discussed recently: Cutting cover over IMRCLike Lupe says, unless it's relocated away from the engine, heat sinks and cutting the cover will only be of marginal help. I guess every little bit helps though.
Posts: 213 |
if you should decided to relocate it, mounting it to the underside of the battery tray is quite convenient.
'98 CSVT
3L Hybrid
"It all comes down to how fast you want your money to go."
______________________________________________
View Profile
Posts: 134 |
The IMRC has a 2N6045 Transistor in it, you know electronics at all, that Transistor is meant to resist heat, im talking well over 1000F of heat, The though of relocating it, or venting it for heat period is a 100% wasting of time. Transistor takes voltage and multiplies it ,same was as a car amp works , doing such a thing makes it hot , VERY HOT ..so like i said ...doing anthing with the IMRC is really worthless IF you know electronics at all .
Posts: 1,325 |
Originally posted by rickse99: The IMRC has a 2N6045 Transistor in it, you know electronics at all, that Transistor is meant to resist heat, im talking well over 1000F of heat, The though of relocating it, or venting it for heat period is a 100% wasting of time. Transistor takes voltage and multiplies it ,same was as a car amp works , doing such a thing makes it hot , VERY HOT ..so like i said ...doing anthing with the IMRC is really worthless IF you know electronics at all .
wow - I had no idea that it was one transistor that was the single point of heat related failure in the IMRC.
Here I was stupidly assuming that it was the BIG ELECTRIC MOTOR under the cover was what was being affected by the extreme heat
97 Contour SE MTX
04 Grand Caravan SXT
Posts: 134 |
Nope , transistor will go out before that will , take out the electric motor and look at the windings . Educate yourself son
Posts: 1,325 |
Originally posted by rickse99: Nope , transistor will go out before that will , take out the electric motor and look at the windings . Educate yourself son
Gee dad, I thought that's what my degree in mechanical engineering had done
Point is - the failure rate of IMRC from heat is a HUGE issue. If you'd bothered to search around you'd see tens to maybe even hundreds of posts about it. Many times near dead IMRC's can be reliably used after removing the heat catcher or relocating them off the valve cover. It's been a proven fix. But if you say it's the transistor in an all knowing tone obviously we're all just dumb! Oh, and I've looked at 2 different motors thanks - the 1st dead one is currently back in use in a friends car located under his battery tray.
97 Contour SE MTX
Posts: 134 |
Originally posted by ScottK: Originally posted by rickse99: Nope , transistor will go out before that will , take out the electric motor and look at the windings . Educate yourself son
Gee son I thought that's what my degree in mechanical engineering had done.Point is - the failure rate of IMRC from heat is a HUGE issue because people dont know what transistors are .Many times near dead IMRC's can be fixed after replacing the transistor . It's been a proven fix. But if you say it's the relocation in an all knowing tone obviously we're all just dumb!
Posts: 1,325 |
Originally posted by rickse99: Originally posted by ScottK: Originally posted by rickse99: Nope , transistor will go out before that will , take out the electric motor and look at the windings . Educate yourself son
But transistors aren't affected by heat
The motor is pulling current in a stalled state when the IMRC is open - ie there is no back-EMF to limit current draw. On top of that it operates in a condition that is hot enough to burn the crap out of human flesh. My vote is still on the motor, but being M.E. I will always look at mechanical failures before electrical. Seening as how a "dead" IMRC can still function normally when cooled - I would think that points in the direction of a motor overheat problem over a burned out transistor that would kill the IMRC permantely, right?
97 Contour SE MTX
Posts: 5,975 |
Originally posted by rickse99: Educate yourself son
Uncalled for and unnecessary. Keep it a discussion, not a pissing contest.
