Posts: 3,223 |
I searched and can't remeber who it was that has gutted stock headers. Who ever that was can you e-mail me or point me in the right direction. Thanks. Aureius@hotmail.com
-Andy
Posts: 3,562 |
Originally posted by Andy W.: I searched and can't remeber who it was that has gutted stock headers. Who ever that was can you e-mail me or point me in the right direction. Thanks. Aureius@hotmail.com
-Andy I've gutted mine... many people here have. I've done a few sets for others as well... what do you need to know?
Brad Noon '99 SE MTX 3 point oh my God H.O. 179HP/178TQ BNMotorsports Floormats, powder coating, TB optimizing, Gutted cats, etc BNMotorsports is now the preferred distributor of Contour/SVT/Mystique Indiglo style gauges!!!bnmotorsports@msn.com
Posts: 1,732 |
andy, if you want you can gut mine and i'll take yours when you (we? :)) do the install.
- Pete - 00 SVT SF/MB - 1522/2150 - DOB 1/12/00 ------------------------------ 92% says your group-NOT HOT 85% says your either wrong or BLIND Blackhawk Down did NOT suck you know who you are.....
Posts: 3,223 |
Brad, The backside header I can see pretty easily ,how to gut it. I'll use an impact gun or hammer and chisle. How do you get the front one. That big bend at the bottom has to be rough working around, if its possible. Do you see any preformance gains and does the sound level change much. Thanks
Pete, Matt's gonna give me his. Thanks Anyway!
-Andy
Posts: 3,223 |
Posts: 3,562 |
Originally posted by Andy W.: Brad, The backside header I can see pretty easily ,how to gut it. I'll use an impact gun or hammer and chisle. How do you get the front one. That big bend at the bottom has to be rough working around, if its possible. Do you see any preformance gains and does the sound level change much. Thanks
-Andy I drill about a 5/8" hole in the bottom of the bend and use a hammer drill with a 12" long bit. When I'm done, I weld up the hole. If you do drill a hole, you need to make sure you still get out all of the packing material and thesteel wool type stuff as well. While breaking the cat material out, I taped an operating shop vac hose onto the end of the output side of the manifold to keep dust down and ease the process a bit. Good luck if you go for it.
Posts: 972 |
im assuming your talking about the precats??...
95 SE Champagne Mettalic True Dual exhaust with X pipe and Redline mufflers KKM Tru Rev intake H&R Springs/KYB struts Apex-i S-AFC 65mm Throttle Body 17" Ace Spades 4 Pt Racing Harness Window Tint all around New Engine @ 117k kilometers G-Tech: 15.6 @ 91.5 MPH
"you officially kick ass" quote from awed CEG'er after i chopped my hood and threw on scoops
RIP 98 SVT silverfrost *nov 4 2001*
Posts: 3,223 |
The pre-cats are on the headers!
-Andy
Posts: 3,248 |
Andy, are you going to do this yourself or do you have a shop in the MD/VA area that will pull & replace the manifolds?? I'm contemplating this as well.
1999 Amazon Green SVT Contour (#554/2760) Stock SVT Duratec V6 with: Intake- K&N filter/75mm MAF meter Exhaust- MSDS Y-pipe/Bassani catback Durability-Ford "dual mode" damper, Mobil 1/K&N oil filter 179.2 FWHP at 6900 RPM
Posts: 3,223 |
Well, My dad owns a shop in Upper Marlboro. Matt M. and Pete have both offered theirs up. I'll give them mine when I swap them out. Matt M and I did Pete's MSDS headers. I'll probably do it with Matt's and install them when I have 5 hours to burn.
-Andy
