Posts: 1,795 |
Originally posted by David Z: I've had it in redline in 5th gear once, back end felt kinda floatly... I forget whom, but someone did the calulations once and for you to readline in 5th it's around 160 or so, which unless u have massive power adders is a little unlikely..unless maybe u are on the dyno :p
Every time I come online I wonder if the forums will be up
Posts: 3,636 |
Originally posted by Pete D: Originally posted by David Z: [b]I've had it in redline in 5th gear once, back end felt kinda floatly... I forget whom, but someone did the calulations once and for you to readline in 5th it's around 160 or so, which unless u have massive power adders is a little unlikely..unless maybe u are on the dyno :p [/b]Like a 3L maybe. TB
Tony Boner Personal: 98cdw27@charter.net Work: tony.boner@sun.com Saving the computer world from WinBloze as Unix/Solaris/Java Guru http://www.sun.com 1998 Contour SVT Pre-E1 618/6535 Born On Date: 4/30/1997 Now with Aussie Bar induced mild oversteer.
Posts: 181 |
It's very stable...this depends on the tires your using. Yes I know what the stock tires are/were, still different tires perform differently.
It's all about the rubber baby.
Posts: 803 |
Originally posted by javaContour: Originally posted by Pete D: [b] Originally posted by David Z: [b]I've had it in redline in 5th gear once, back end felt kinda floatly... I forget whom, but someone did the calulations once and for you to readline in 5th it's around 160 or so, which unless u have massive power adders is a little unlikely..unless maybe u are on the dyno :p [/b] Like a 3L maybe.
TB[/b]Or a slipping clutch.....
hunter green 96 mystique mtx, sabb side markers deep tints car bra., K & N filter, hyper white low beams, after market fogs, JVC Kameleon head unit, 600 watt amp with 2 10" kicker subs, soon to come new rims
New adition 01/11/2002 The original 95SE in Midnight Red all the toys including traction control Fog light mod, lightmoonroof switch from a focus, power antena (still wiring it up) post 98 sail panels, new water pump , Bosch quad plaitnum plugs, and a new Cat.
Posts: 3,636 |
Originally posted by mbb41: Or a slipping clutch..... How would a slipping clutch increase your top speed. Speed is determined "Downstream" of the clutch. So if a clutch were slipping, the tach would rise, but the speedo wouldn't. But that's what you meant, right TB
Posts: 620 |
I do the 140 thing every so often (my tires can handle it) fells real good..extremely stable (you can tell normally when friends freak out @ high speeds, mine don't mind speed in this car)
SVT EMBLEM MOD HERE :::96:C:LX:::Black 2.5L ATX "my beater" - Shaved ? badgeless ? SE rocker panels :::99:SVT:C::: #2566 of 2760 T-RED/TAN "the bitçh" Brullen Cat-back w/ 3.5" angle-cut tips ? BAT European Suspension ? AFE Filter ? CnL 73mm MAF ? Diablosport Chip :MNQ3: ? Mirko front spilter ? Apexi SAFC (i'm scared to install! anyone in Norcal wanna help me?) ..::nyceboicreations.com::.. email:junkmail@nyceboicreations.com
Posts: 7,329 |
Max speed attainable at 7k and stock 24.5" tires is a hair below 169mph...
However the 200HP SVT is drag limited to 143-144mph... 150mph at ~240HP (~195FWHP) 160mph at ~290HP (~240FWHP) 170mph at ~340HP (~275FWHP) (rough estimates)
Also like stated before. The stock speedo is quite generous once you get above 100mph.
Deviation from stock tire size will make this exponentially worse.
Posts: 2,708 |
Well, I have well over 275fwhp and a 7500rpm redline, and the gps indicated 172.8mph w/ 6 satellites tracking.
-Mark
You can do something for Love... You can do something for Money... But there is nothing quite so satisfying as doing something out of Spite. GTExtreme1@aol.com
Posts: 803 |
Originally posted by javaContour: Originally posted by mbb41: [b]Or a slipping clutch..... How would a slipping clutch increase your top speed. Speed is determined "Downstream" of the clutch. So if a clutch were slipping, the tach would rise, but the speedo wouldn't.
TB[/b]Just saying that if the clutch were slipping and the speedo was inacurate (yes I know 2 variables). however unlikely it could happen. Of course if pigs could fly...... :p
Posts: 1,619 |
Originally posted by WorldTour: Well, I have well over 275fwhp and a 7500rpm redline, and the gps indicated 172.8mph w/ 6 satellites tracking.
-Mark Wow!!
95 Mystique LS Young America edition, V6, MTX, Yeah...it's stock. Now with new underhood wiring!!! My Profile Moderator of the Florida Contour Enthusiast Group
