#1051443 09/14/04 07:37 PM
Ok, after replacing all O2 sensors, IAC valve, and PCV valve, I still have a bad idle problem. Sometimes it works fine, and other times the idle will fall down to 400rpms or even stall out. This happens when i put the car in neutral to slow down and stop, or when I come to a complete stop. I have a cel right now, P0455 Leak or Blockage Detected in Evaporative Emission Control System. Can't seem to find whats causing it. Replaced the gas cap, but that didn't do anything. Still came up. By the way, I had three cels before, all for 02 sensors. When replacing them, I also replaced the pcv valve, and now the O2 sensor cels are gone, and this new one is here. I already asked about this cel code and what to check for and someone listed this entire thing on what the emissions control system is, but no suggestions on what to fix or replace. Could the brand new PCV valve be bad? Please help me get this fixed, because I've been having this problem for over a month now with no fix, even after a mechanic raped me.
Heres a link to the last thread
Link
AIM...BKapp17 98 T-red SVT Steeda Gutted Pre-cats, no resonator Painted Dash Angel Eye Fogs Painted Chrome ring / headlights Looking for a t-red pre98 trunk lid
#1051444 09/14/04 08:35 PM
O
O
I don't see where you mention throttle position sensor. Check thru the previous posts and you will find some info on the subject. I am not an expert, just passing along what has been given.....Steve
#1051445 09/14/04 08:38 PM
Z
Z
What type of PCV Valve did you use?
IIRC, our cars are very sensative and people here recommend that you use only Motorcraft PCV Valve.
- Zack WANTED: T-Red HEATED Side Mirrors FOR SALE: 4 14" Alum Alloys and Nearly New Avid H4s Tires w/ Center Caps 2000 T-Red SVT 1995 LX V6 MTX (RIP)
#1051446 09/14/04 10:18 PM
about 24 dollars.........
Bob
#1051447 09/15/04 11:43 PM
My 99 SVT does the same thing sometimes when I throw it in neutral, or like you said stop, and im gonna replace the Throttle Position Sensor, and the IAC valve anyways.
#1051448 09/16/04 12:20 AM
Where is the Throttle Position Sensor?
#1051449 09/16/04 02:47 PM
If you have a Duratec it's right here.
1996 2.5LT V6 Contour ATX My Tour+help/info pics E0 rims, Gutted Pre-Cats,CTA Custom Exhaust & Intake, Diablo Chip.
