#105039 09/10/01 03:23 PM
What is the diffrence in power?
Michigan CEG BenTonEdge@aol.com
**DEAD** Dec26 01. 96 2.5 Gl dessert violet. mystery mod, gutted cat. no res. craked secondaries. custom air box. And a good old CEL Oh you want to know
#105040 09/10/01 03:51 PM
Well, very similar I think mod for mod. Our only car with hotter cams is David Zs - has 3L valves, SVE cams, headers and makes 240 FWHP. Check the SHO -shop stage 4 3.0L package dynos. They add bigger valves, big butterflys, manifold porting, hot cams, and a bunch of other things and makes about 238 FWHP. The SHO-Shop 3L has stock SVT cams and made 229 FWHP , simlilar to their stage 3 SHO 3.0L.
1999 Amazon Green SVT Contour (#554/2760)
Stock SVT Duratec V6 with:
Intake- K&N filter/75mm MAF meter
Exhaust- MSDS Y-pipe/Bassani catback
Durability-Ford "dual mode" damper, Mobil 1/K&N oil filter
179.2 FWHP at 6900 RPM
#105041 09/10/01 08:44 PM
A guess would be around 20 or so HP. Most of the advantage the SVT would have is the cams and breathing. Guessing around 215-220 or so for the SE and 230 or so for the most basic of swaps with little or no other mods. Not sure until one of the few 3 liter SEs dynoes...
Brad Noon
'99 SE MTX
3 point oh my God H.O. 179HP/178TQ
BNMotorsports Floormats, powder coating, TB optimizing, Gutted cats, etc
BNMotorsports is now the preferred distributor of Contour/SVT/Mystique Indiglo style gauges!!!
bnmotorsports@msn.com
#105042 09/10/01 09:04 PM
Forget my answer, I read the Q wrong - thought you wanted to compare 3L SVT & 3L SHO. I agree with Brad, the SVT cams & Extrude Honing probably account for 15-18 of the 30 extra SVT horses on the 2.5L. So, multiply that by 6/5 for the 3L = about 20 HP.
#105043 09/11/01 03:43 AM
F
F
What has me a little cautious/pessimistic is that the regular 3L only makes 200 HP. The swap with SE heads will give higher compression ratio to the tune of 10 to 15 HP above value with 3L heads, but you have to subtract to account for the fact that the 3L heads should breathe better plus the fact that the 3L exhaust manifold has no precats. It seems to me that one really shouldn't be expecting to get more than 200 to 205 HP at the crank for a 3L block with SE heads - similar HP to stock 2.5L SVT, but 35 to 40 ft-lbs more torque. Doing headers and exhaust at same time might net 220 HP at crank.
I'm willing to buy the argument that the better breathing and hotter cams of the SVT heads are good for 20 HP - that would place a 3L/SVT heads in the 220 HP range which is consistent with the 185 to 190 FWHP that was reported by Roger before any other exhaust or intake mods were done.
In my mind the interesting question for non-SVT owners and who don't want to change pistons is whether to use the 3L heads (better breathing but lower compression) or the SE heads (trade breathing for compression).
But as Brad points out, too few data points so only speculation for now.
Eric
#105044 09/11/01 05:06 AM
Brad, Hint hint.... KC Dyno hint hint... 51.7X for two runs hint hint smile
Got to get you to KC someday smile
Merlin
281hp 324tq
Timing 14' FP 36,24lbs,190lph,75Maf,65tb,cobra upper&lower,B303, GT-40 Crate with X al heads, Mac shorties, Off Road H,2chamber Flow's dumped, Tokico 5wys, Hotichkis Ctrl Arms, Alum Drive shaft, 3.73, Sub Frame,Steeda Tri-Ax, 94 Seats Drivers side powered.
#105045 09/11/01 01:22 PM
Merlin, what are you talking about? A dyno in K.C.? Whatever for? :rolleyes: I'm saving for more mods, dyno time right now is a waste of my money and time. Since I have the 70mm TB and stock exhaust with all cats gutted (shouldn't gut the main one, expansion chamber to far back), which I believe are both hurting my overall performance, I would dyno lower than a base swap 3 liter in an SE. Those mods will pick back up when my dual exhaust is fitted when I have time. Until then, it's up to Micah unless someone else gets an SE or Cougar done before then.
Brad Noon
'99 SE MTX
#105046 09/12/01 03:14 PM
W
W
SHOShop has different stage packages for the 3.0L now? Anyone got a link with prices?
Thanks!
#105047 09/12/01 03:19 PM
F
F
****, SHO-Shop's website is a joke! Doesn't anyone understand that a website can be their best salesman? Vadim really needs to reasses his website thinking. They offer MULTIPLE parts that aren't even remotely mentioned on their site. DUMB DUMB DUMB!
Best Regards,
Trevor Cole
New Edge Cougar Forums
#105048 09/13/01 04:25 AM
Yes sho shop is a very small business, doesn't upgrade their website, and doesn't have particularly good customer service. I myself have talked to Vadim on several occasions and he certainly seemed to be very knowledgable about our cars. He has no problem just talking about our cars, and sharing alot of information.
I spoke with him very recently about everything that he offeres for the 3.0 upgrade. Right now there are not really "stages". He has been looking into doing a big valve job on the svt heads, but is worried about the valves "burning out". Now I don't know much in-depth information about the specifics of heads, but basically what he was trying to explain was that with the vavles in there wasn't much room left within the head, and that it MIGHT not be reliable. One again he wasn't positive.
Now one thing that I am wondering is whether or not headwork is really worth it on the svt. David z has big valves, P&P heads, and more aggresive cams, yet he only dynoed at around 5 - 12 Hp more than vadim (sho shop). vadim had no headwork done except for some port matching.
So, I found the best way to get a hold of vadim is too call in and leave a mesage, or fax them your question with your phone number on it. Whenver I faxed him I got a response that day.
Hope this helped
James
SVT with CE light mod and a camera mount.
Naughty Pictures
Why yes it is true, I am on my third engine.
