#1048947 09/11/04 06:31 PM
dre1010 Offline OP
When I have my defrost on or a/c on in my car. I have a problem with a idle that goes up and down, when I am at a stop. It idles low then it kicks up then down etc... it does this over and over again until I take off. I have a 96 gl with 120,000 miles. Thank You.
#1048948 09/11/04 06:54 PM
Your A/C system might need to be recharged. If A/C is on and you hear the system cycling on/off rapidly.
It could be your IAC (idle air control) valve.
I would never trouble shoot an A/C/Idle problem as it's expensive to guess and throw parts at it.
Not to mention wasting refridgerants.
1996 2.5LT V6 Contour ATX My Tour+help/info pics E0 rims, Gutted Pre-Cats,CTA Custom Exhaust & Intake, Diablo Chip.
#1048949 09/11/04 08:42 PM
9
If it only happens when the a/c or defrost is on then it is most definitely low on refridgerant. Charge it up and it should go away but you may need to fix a leaky component also.
I live in Detroit, I couldn't give a **** how good my car is in the "twisties." "I could use a hundred people who don't know there is such a word as impossible." ~Henry Ford
#1048950 09/12/04 02:30 AM
H
H
Not true, my car does the same thing idles up and down 500-700 with only A/C or defrost on.
I had my system recharged like a few CEGers said and it didnt fix it, it still idles up and down just not as often for some reason, also there is no leak they used the dye no leak was present.
