Posts: 430 |
Lee Cox
No Contours to speak of...
Posts: 3,887 |
Pull the pan off the SVT motor and check it out, perform a compression test. If it checks out drop it in.
06 GMC Sierra 2500HD Dmax/ally
06 Pontiac G6 GT
05 CRF250R
FOR SALE 06 KX65 with riding gear $2700 obo
Posts: 33 |
How do you do a compression test on a engine with it outside of the can and non running
Thanks in advance
Posts: 4,693 |
The engine does not need to be running, in fact the common common compression test with a pressure gauge is done with the engine off. You do, however, need to be able to crank the engine in the normal manner with the starter. I would think this would usually be very difficult if the engine is out of the car.
Jim Johnson
98 SVT
03 Escape Limited
Posts: 2,779 |
Exactly my thoughts. That's why I said I hope he checked out it's running condition before removing it.
Posts: 3,887 |
If he had the trans he could just put 12 volts across the starter and test away. It would be kinda funny seeing someone testing the motor trans outta the car like this and haveit jumping and bucking from a hanging engine stand....for some odd reason I keep picturing that scenario
06 Pontiac G6 GT
05 CRF250R
Posts: 768 |
good ol' days:
Posts: 2,779 |
you wouldn't need the pcm to get it to crank? i don't see why you would need the trans, just the starter...
Posts: 3,887 |
Originally posted by JonnySVT: you wouldn't need the pcm to get it to crank? i don't see why you would need the trans, just the starter...
starter is bolted to the trans
06 Pontiac G6 GT
05 CRF250R
Posts: 9,602 |
Originally posted by Thinkmoto: Originally posted by JonnySVT: you wouldn't need the pcm to get it to crank?
Sorry that just needed it...
2000 SVT #674
13.47 @ 102 - All Motor!
