Page 2 of 3 1 2 3
#1048552 09/11/04 02:22 PM
Originally posted by Goonz12 (SVT):
Originally posted by brapple:
yes if you cut the tabs off the light you can put the highs in your lows,
you mean the tabs at the end of the bulb, the pointy rubber thing?
not really sure, compair a high and low beam light and you should be able to see the difference, the tabs area suppose to keep the high beam from connecting to the low beam plug
#1048553 09/11/04 05:14 PM
W
W
Use a dremel to carefully remove the tabs inside the 9005 plug. That way it'll plug in and still lock. The difference is amazing. You can now actually see at night and people won't be flashing their lights at you. The signs on the right of the road will be lit up better also. I've spent a small fortune trying to get bulbs that light up the road better than stock but the Silverstars are the best, IMHO. I even like them better than PIAA's for the headlights. They're not super white but they're not yellowish either. Do it, you won't be disappointed. Get the 3457 parking lights too.
Make sure you don't touch the bulbs. If you do, clean them with alcohol to remove any oil you may have deposited on the bulb from your fingers.
WA 2 TUFF SVT 2000 Tropic Green SVT Born 1/28/2000-1975 out of 2150-only 207 made. Some new pics
#1048554 09/11/04 06:30 PM
Yes, Goonz I was referring to putting the hi bulbs in the low housing. Try to install one the way it is and you will see what is blocking it. There's a tab that runs down the center of the inside of the bulb's connector, it needs to be shaved down.
99 SVTC, T-Red, #652/2760-12.8.1998 Mother#@%@!* did I sound abstract? I hope it sounded more confusin than that!
#1048555 09/11/04 06:33 PM
I
I
go buy a brand new pair of cotton glove inserts before installation!!!
cardomain 98 Contour SE zetec I-4
#1048556 09/11/04 06:35 PM
#1048557 09/11/04 06:37 PM
I
I
i blew 2 bulbs (just cheap knockoffs when replacing my highs... i bought the gloves and didnt get any oils on the lights... worked for me though i am a cluts
#1048558 09/11/04 06:39 PM
or whip the bulbs down with rubbing alcohol right before you install them
#1048559 09/11/04 06:40 PM
Did you ever think about trying a rag or a mere paper towel? Or are these magic gloves that also install the lights for you?
#1048560 09/11/04 06:43 PM
I
I
they are the magic kind they changed my lights and put my car at a 6 second qaurter mile... i wanst even in the car while they did it... they musta been pushing hard to... in all honest i have no idia... i use what worked for me and figured it might make it easier for others
#1048561 09/11/04 06:54 PM
I guess I'll go out and buy some, I'll hafta get rid of the 9006's silverstars if I use my highs as as lows then what do I do with my highs?
Page 2 of 3 1 2 3
