Posts: 504 |
I've had my contour for almost two years now. It's a 1996 gl atx (4 banger). Well, throughout those 2 years, my car has declined astheticly. Some were my fault and some were not. Here's the problem, do i fix her up or do i get something else. If I were to fix her it would probably mean a new trunk lid, new front and rear bumpers, a new passenger side mirror and O rings (i think). With the o rings, i switched to synthetic oil a while back and started losing oil. I switched back to regular oil but everytime i accelerate hard, oil comes out of the breather tube. Think i should fix her up or try to get the most money with the condition it's in and get something else?
"Here's a mirror, see your stupid face!"
b0x @dm1n
b0x @dm1n
Posts: 4,397 |
Replacing o-rings would increase oil consumption. It's pretty much a proven fact that if you don't hone the cyliner walls replace the cylinders and do the o-rings you'll end up with more oil burn.
What makes you believe that is what is causing the brun anyway?
-Andy
Andy W.
The problem with America is stupidity.
I'm not saying there should be a capital punishment
for stupidity, but why don't we just take the safety
labels off of everything and let the problem solve itself?
Posts: 504 |
Originally posted by Andy W.: Replacing o-rings would increase oil consumption. It's pretty much a proven fact that if you don't hone the cyliner walls replace the cylinders and do the o-rings you'll end up with more oil burn.
-Andy
thats what i've been told that was most likely the culprit. It's not even really burning oil, it's blowing out of the breather tube upon hard acceleration.
b0x @dm1n
b0x @dm1n
Posts: 4,397 |
That's not you piston O-rings. That likely the a valve job!
-Andy
Andy W.
Posts: 504 |
Originally posted by Andy W.: That's not you piston O-rings. That likely the a valve job!
-Andy
and how much will they reem me for that? (which brings me back to the original question, fix or sell her?
b0x @dm1n
b0x @dm1n
Posts: 4,397 |
Sell and buy a used Focus!
-Andy
Andy W.
Posts: 4,760 |
Love the Sig andy
Team Evo
Staz: You know why they call it Skunkworks?
Everyone: Why?
Staz: Because everything that comes out of it stinks!!!
Steeda-I hate you stazi
Posts: 32 |
Sell it and get something newer. If oil is coming out of the breather tube you have some significant problems in your engine. When my last car did that it was the piston rings = overhaul = big bucks. Check the compression in each cylinder and if one or more is low that is likely the culprit.
"A job will always take TWICE the time you think you need."
Posts: 839 |
if you gotta get all of that................its time for a new car. good luck with it.
Posts: 3,496 |
Its a '96 base model, value in good running condition is around $2K, yours sounds real bad, body wise and engine wise.
Get your $500 and move on.
