Posts: 24 |
just wondering how much a new fuel pump costs thanks
2000 silver frost midnite blue csvt
Posts: 2,725 |
FUEL PUMP, Contour, Mystique, 2.5L, From 5/3/99 99-00$202.43 Includes: Fuel Sending Unit That is of course buying a Motorcraft one. Here
Posts: 1,746 |
You can buy a direct replacement from SP Motorsports, or the Focus SVT pump from Signature LM, both for under $100.
Posts: 496 |
https://www.1stfordparts.com/ They have a pump for a little cheaper. I don't know where they're located though.
Posts: 2,445 |
Or you cvan get just the sending unit from BAT for $80.
2000 Contour SE Sport
Originator of the Beowulf Headlight Mod and the Beowulf CAI
Posts: 810 |
No you can't, BAT isn't selling them for ~$80 like they used to. They're getting the same OEM ones that Ford sells for $300 and are around that price also.
Posts: 10,015 |
Order the fuel pump unit for the Focus SVT. It's $100 and you get the whole contraption for the Focus, but all you end up using out of it is just the pump. It's a 255lph pump compared to the crappy 150lph original. Don't waste you time iwth ANYTHING else. You have been warned.
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
Posts: 3,115 |
I you have a mechanic put it in, he won't let you use the Focus smart pump due to the mods required. I just replaced mine using the stock OEM part and it cost me $450. That included dropping the tank, cleaning it out, replacing the fuel filter and flushing the fuel system.
TR
"Eagles may soar high, but weasels don't get sucked into jet engines."
Posts: 10,015 |
 do it yourself then or have another CEG'er help you! $450 ouch - did he lube you up before that or just ram it in dry?
AUSSIE ENDLINKS $70
Posts: 3,115 |
Originally posted by Stazi:  do it yourself then or have another CEG'er help you!
Just bent me over. He had the tank out and called me and said he would not use FSVT pump I had bought. So, I had to get a stock unit so I could get the car back that day.
