Mega fuse is on the back of the motor behind the coilpack. Its in-line with the charging cable that goes from the alternator to the battery. Use a multimeter to test. If its good, and you're sure no wires are disconnected (There is your charging wire, a maybe 4-5 wire harness, and a small 18 guage field wire that all plug into your alternator). Then your alternator is probably crapped out. Dont feel bad, my car is on its 5th alternator since 1998.
1998 Contour SE 2.5L Duratec DOHC 5spd. "Who needs a working IMRC? - I don't." 1968 Chevelle 300 Deluxe 1994 GMC Yukon SLE 1972 Plymouth Roadrunner - restoring for a friend.
