Posts: 50 |
Originally posted by RoadiJeff: How do I see if the alternator is working?
Stop by AutoZone. They'll test the charging system and battery for free.
I would, but I cant even move the car (it aint starting) lol :-x
1999 Contour SVT
Posts: 1,505 |
start the car and while it's running at the same time disconnect the negative on the battery if it's dies it's your altenator if it doesnt it's your battery
1999 Ford Contour SE Zetec with 137k miles.
AIM Name: ContourAlf
Yahoo IM: Contour_Freak
Cool Toe Chris
Cool Toe Chris
Posts: 1,825 |
Originally posted by Stryker: on an SVT, you better line your pockets with cash. they arent easy to get at.
You are so uninformed. Same alternator for the V6 line. I have one for sale. Drop me a PM.
Chris
NJ
98.5 SVT Silver Frost
Posts: 50 |
Originally posted by contourfreak22: start the car and while it's running at the same time disconnect the negative on the battery if it's dies it's your altenator if it doesnt it's your battery
I will have to try that, thanks for the tip!
1999 Contour SVT
Zippy Zetec on his last legs.
Posts: 1,262 |
Originally posted by Shaggy: Originally posted by Stryker: on an SVT, you better line your pockets with cash. they arent easy to get at.
i meant compared to the zetec they arent easy to get at! i know the alternator is the same....jump down my throat, will ya?
on a V6, comapared to the zetec, a shop is going to rape you on labor.
Thats what i meant. i guess its partly my fualt for not being clear.
apologies...
Regards, Cole.
Relegating to troll status sometime this week.
New Whip: 1990 Lexus ES250.
Old Hotness: 1995 GL MTX Zetec *IN TRIAGE*
"I had a little friend once, but it dont move no more...  "
Posts: 50 |
lol, yea I found out their a pain to get at (pretty impossible unless you take the whole shock harness n junk off....ahhh what a pain
1999 Contour SVT
Posts: 463 |
Never disconnect the battery when the engine is running to test the alternator! That might have worked fine on your dad�s 67 chevy but it can blow the entire electrical system on you countor. An unregulated alternator can easily produce over 60 volts. You pull out the battery (the only thing holding it back) it's goodbye PCM and the works.
Basic testing of the battery and alt is simple. Go to radio shack and buy a cheap digital voltmeter. With the car off, measure the battery voltage. If it is under 12 volts replace the battery. If it is 12 or more start the car and measure the voltage across the battery, it should go up to about 14.4 volts and then drop to about 13.4. If it does, then the alt/reg is good.
jeff
have you fixed your ford lately?
Posts: 50 |
With the car off, the voltmeter shows 12.17 volts, but without a jump, I cant start the car....it doesnt work even when it reads 12.17 volts....
1999 Contour SVT
Posts: 808 |
Jeez man... your battery may be good when sitting still but when you try to crank it, place it under load, many dead batteries will drop their voltage like a chevy drops engines......
whatever... some batteries will appear to be good but will actually be dead. Try this.. get a load tester. Hook it up and test the voltage. Now place the battery under the load feature and see if the volts drop. If it does then replace the battery (or try charging it first). Once it is charged then crank the tour.
Now with the tour running, place the voltmeter on the battery. If the battery is dropping in volts then it's not getting charged. If the volts is 13.5-14.5 then your system should be charging and the problem is elsewhere.
95 Mystique GS Zetec ATX: Dead - Dec 5th, 2003
94 Accord LX 2.2L MTX Non-Vtec. Few bolt ons.
02 Escape XLT 3.0 V6 ATX. This thing has the CD4E in it?! What the hell was ford thinking?
Posts: 50 |
I got no idea what you want me to do, lol, right now the battery is readon 12.17V, I cant start he car, it will start if I hook up a jumper cable, but as soon as I disconnect, the battery V goes down....Isnt it obvious that my alternator is dead, or is there still a possibility its only the battery?
(I got to the alternator about 30 mins after I shut the car off, and the alternator was still hot, dont know if that means anything)
1999 Contour SVT
