Posts: 912 |
I ordered one from mean green and recieved it within 3 days, they were extremely helpful to me when I dealt with them about a year ago. The alternator is great, but there is only about 200 miles on her, and I have not tested it yet with a extensive system. I have the 200 amp alternator with 0 gauge wiring.
I recommended this company to SVT ST PETE and he went through extreme amounts of bull$hit with them including much wasted time. Due to this I hesitate recommending them to you, the only thing I got out of pete's situation is IF you do want to order something from them, ask them if the parts are in stock. If they say yes, I would assume its ok, but if they say no, I would not order. They told him they were waiting on parts for a while.
Buyer definetly beware...And don't say we didn't warn you!
Jason
00 Audi S4, 2.7 Bi-turbo quattro
01 S10 Xtreme, 4.3l
98' Contour SE with some mods
96 Cavalier (beater)
Posts: 1,859 |
Originally posted by selfinfliction: does anyone think its possible to have the stock altenator rewound to pump out 160 amp like the one on pa-performance? one of my father's friends owns a altenator/generator shop and he can usually rebuld them to get a little more power out of them with different brushes and windings, but i never cared much to ask. has anyone had somehting like this attempted? cause i know it would be a lot less that $200.. prolly more along the lines of $100 if he does it. (if he can actually get a substantial amount of ouput increase i'm not so sure though)
I actualy considered this myself. I drove over to an alternator shop not to long ago, but it was closed. Been to lazy to get back.
On side note, I emailed Pa a couple days ago now and have not recived a response.
'99 Silver svt
For sale
19" Axis Neo wheels
3.0 parts, pre-98 trunk,
Check classifieds
bp.powell@comcast.net
Cool Toe Chris
Cool Toe Chris
Posts: 1,825 |
I never emailed them, but called them on a number of different occasions and they were always helpful.
Chris
NJ
98.5 SVT Silver Frost
Posts: 2,728 |
Originally posted by tropictour: Sounds to me like your alternator is going out. I would get it checked out at the parts store. Its free!
That's to get your alternator checked out, correct? I was having big problems with the CEL flashing at high RPM's a while back. It hasn't been doing it for a while, but I havn't had the RPM's too high in a while either. I'd like to at least see if it is the alternator and how much longer until it goes. Would Autozone do it?
'03 SRT-4
50 trim turbo + support
Posts: 9 |
i think autozone might do free testing, not sure though.. i would like to know cause then i can drop by there myself, just to verify my issue
Posts: 1,145 |
you dont need to buy a 200a alternator you already got one, well atleast i do  , when i had autozone test mine it put out ~197a, i was like WTF it is a 130a alternator, the guy was like i dunno  , even with the output that high, if it really is, my lights dim really bad at idle, so sometime in the near future i plan on upgrading the wiring like someone said above, see if that helps if not then i will replace the damn thing
98.5 Black SE ATX
Posts: 9,602 |
Originally posted by gearhead98: you dont need to buy a 200a alternator you already got one, well atleast i do , when i had autozone test mine it put out ~197a, i was like WTF it is a 130a alternator, the guy was like i dunno , even with the output that high, if it really is, my lights dim really bad at idle, so sometime in the near future i plan on upgrading the wiring like someone said above, see if that helps if not then i will replace the damn thing
That's because the yahoo testing it put the inductive lead on the wrong source wire. (Not all Parts People have a clue!)
It just tested the load (which is 200A btw) the ARBST machine put on the system to get the alternator to max current at a set rpm. (which for the test is just 2000rpm)
Go have it tested again and make sure they do it correctly this time.
Also at 2000rpm you will not make 130amps. A guesstimate would be more like 90amp with it reaching 130A by 4000-5000rpm and maxing maybe 10% higher then rated at 6000-7000rpm.
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 3,732 |
im having my alternator rebuilt, will be getting it back tomorrow probably. $95 for a COMPLETE rebuild w/ warrenty
Russell
Oval Port 3L Nearly Done
Posts: 9 |
is it just an oem rebuild or are they gonna juice it up with new brushes/winds?
Posts: 3,732 |
just a factory spec rebuild
Russell
