Page 2 of 2 1 2
Originally posted by Darksavior:
ok you guys told me what a p0133 code was.. saying it was the front o2 sensor. Whats a p1131 code?
search
-Ken V. 1998.5 SE Praire Tan Zetec ATX psycho_bass@hotmail.com Roush springs Roush rear sway bar BAT struts 17" Millie Miglia HT3 and a ton of subtle asthetic mods
sorry ... my bad ... never occured to me the codes would be here...
1997 Countour GL Sport Red ATX 2.0 Tinted Windows Resonator Removed Ngk Laser Platinum plugs Sony X-plode Head unit, Pioneer 3 ways 6x8's 2- 10" PPI subs in enclosed box Powered by PPI2240 Amp
No biggie. That link I posted is to a thread that explains the code pretty well.
Ok ... so my timing belt tensioner blows up. No problem
Same here
Next Brakes go to hell... no problem.
Same again
Engine light comes on !!get that fixed.
Oh for about a year for me. I had carbon buildup in MAF from not clamping CTA filter and got it and the valves de-carbonized, all better.
Try those sensors mentioned.
1992 Ford Escort LX-E -Tracer LTS spoiler -GT Grille
F
F
Originally posted by HITMANinMI:
Your TPS isnt bad as someone said, that wouldnt cause your idle to go up and down and stall out.
Wrong. Erratic idle, with normal behavior at driving speeds, is the exact symptom for a bad TPS sensor. Of course many other things could also cause this, however, a bad TPS results in an erratic idle none the less.
96 Sport 2.0L - 190,XXX miles
P1131
Front oxygen sensor circuit malfunction (short circuit)
P0133
Front Oxygen Sensor Circuit Slow Response
Well.. I think boths codes are trying to say the Front Oxygen sensor needs to be replaced.
As far as crappy idle goes... oxygen sensors can do this.
I can think of a few other things at this point if you have
not taken a look at them. Cracked or melted PCV Hose extensions, you can find these under the car.
Page 2 of 2 1 2
