Posts: 26 |
i think it is some electrical thing. i will give it a look this week. can anyone tell me where that cable goes?
99 Amazon Green/Tan CSVT 66k Miles
* Tinted Windows
[img]http://img.villagephotos.com/p/2004-12/915133/grn99toursmall2[1]_23491043.jpg[/img]
Posts: 937 |
This can be a pain in the arse job if you have never removed a set of rear brakes before. ![](/ubbthreads/images/graemlins/laugh.gif) The cable should run from the handle inside the car back to the driver side drum brake system. You will see a funky end on the brake system that looks like what a bike would use only bigger. ![](/ubbthreads/images/graemlins/crazy.gif) So when you pull on the handle it locks the brake pads down good and tight. The pain in the arse part is feeding this sucker through the system and getting the brakes on or off. If you are lucky you will not need to remove the brakes, but you can never tell until you get that far along. It might not be a bad idea to take pictures so you can work your way back and maybe use the old cable to feed the other one into the same place would be a good idea. Duck tape might work well for that idea, no? Blah... I'm just babbling here.
Posts: 1,012 |
Originally posted by Hubes914: i think it is some electrical thing. i will give it a look this week. can anyone tell me where that cable goes?
Just wondering because I don't have whatever the hell that is on my car...Hmm...
Posts: 937 |
Originally posted by FreeShyne: Originally posted by Hubes914: i think it is some electrical thing. i will give it a look this week. can anyone tell me where that cable goes?
A bomb perhaps?
Posts: 644 |
Originally posted by FreeShyne: Not related, I know, but what is that silver box in front of the ebrake?
It's part of the airbag system. I believe it contains sensors that judge the severity of an impact.
1999 Red / Tan SVT
#1969 of 2760
Built 4/21/99
K&N, DMD, FMS Wires, ES Insert / Bushings, PF End Links
17" FSVT 5-Spokes
Factory Spoiler
35% Tint All Around
Posts: 1,012 |
Originally posted by delmar: Originally posted by FreeShyne: Not related, I know, but what is that silver box in front of the ebrake?
Sorry to hijack, but is that bad that I don't have one of those? Why the hell is that?
Posts: 644 |
Originally posted by FreeShyne: Originally posted by delmar: Originally posted by FreeShyne: Not related, I know, but what is that silver box in front of the ebrake?
Maybe it's a post-98 thing? I don't know. I just saw the warnings all over it when I took my console apart.
1999 Red / Tan SVT
#1969 of 2760
Built 4/21/99
17" FSVT 5-Spokes
Factory Spoiler
35% Tint All Around
Posts: 3,335 |
Originally posted by TronX: This can be a pain in the arse job if you have never removed a set of rear brakes before. ![](/ubbthreads/images/graemlins/laugh.gif)
I cant recall how the cable looks under the console, but it exits the car as one and splits into two cables above the heat shield covering the exhaust system, just in front of the fuel tank. From there is splits and goes to the rear wheels. Its a sectional system so you will only have to replace the one cable.
Hopefully this will save you some time trying to find where the cables go.
· Jon Miconi
· Coming Soon!
· 01 Cougar
· 98 V70R
Posts: 183 |
I have had all kind of problems with the rear brakes and the ebrake on my old 95. I had that cable snap too. The part was the whole handle and the cable for onrly like $40. The e-brake system is three parts. A short cable from th ehandle goes to a bracket that has a cable to each wheel. You all ready did the hard part taking of the console. Next jack up the car and but good jack stands under it and drop the exhaust. Disconnect the cable remove the handle assembly and put it all together. While you are at it you may want to change the cables to the brakes.
Rich S.
1998 SVT
1995 Contour 2.5 MTX 215K miles Son's car(dead and buried)
1997 Contour 2.0 ATX
1998 Contour 2.5 ATX
2004 Tauras Wagon 3.0 Duratec
Posts: 26 |
thanks for the help guys. i will look at that silver box to see what it says on top of it this weekend. if i were to have this done at a shop, how much would i expect to pay. i have limited space (apartment complex) in which i am not supposed be working on vehicles. will most shops let you bring in the part and have them install it? should i take this to midas or one of those brake places?
* Tinted Windows
