Page 7 of 7 1 2 3 4 5 6 7
#1040504 09/15/04 03:30 PM
H
H
W/A is IIRC 14:1 heat transfer verses 1:1 for A/A - I dont follow your logic.
as long as the water is below charge temp it will have its 14:1 cooling capacity in the IC. Ice would certainly increase the heat removal efficiency but is not needed.
Right, but I do not beleive thats usualy the case. Especialy in the summer months. Well placed fmic for good air flow with minimal pressure loss and properly sized would be optimal for street/road race. Drag race, bring on the water and ice.
so your telling me that for a tour a radiator is not usually heat transfer effecient unless at a drag strip??? because that is what a W/A intercooler uses to cool its charge ( and then another to cool the water), and unless you got a bad case of plastic impeller your radiator does a marvelous job cooling the engine. If you cant see where im going with this then never mind.
having said that - my MSP has an A/A "Fmic" and it works well enough, but in its stock location could benefit from better air/flow, also something to think about when comparing the 2. the tour aint got much space
Tea 82 242Ti Proud former owner - Samantha '98 SVT #2253 Reborn Aug 21 2002 Cobra Paradise
#1040505 09/15/04 04:01 PM
Relax you keep hashing things I already stated. We already no it will take much work to fit well in a tour. As far as the radiator deal, if you use coolant instead of water as the media, like I beleive 04 Cobras use, yes that makes a difference as well. But mose "Tours" are using straight water, not as effective.
'99 Silver svt For sale 19" Axis Neo wheels 3.0 parts, pre-98 trunk, Check classifieds bp.powell@comcast.net
#1040506 09/15/04 06:16 PM
Huh?
Water has 2.4 times the heat transfer ability as standard "green" antifreeze.
Straight water is preferred. Actually maybe throw in a bit of iso/polypropyl alcohol to raise efficiency and add a little protective additives. (Like a water wetter type additive package)
Antifreeze is just that. Anti-freezing additive with corrosion inhibitors added.
Old fashion "green" antifreeze even adds phosphates and silicates to the mix. NO THANK YOU!
#1040507 09/15/04 06:51 PM
I agree with adding the aclochol. What are the cobra/lightings using? Straight coolant, high mileage stuff. I haven't been able to examine one up close.
Now mix that water/aclchol, or better nitrous even Co2, and spray the I/C, you can make that air/air pretty effceient, if all other precautions are taking. Still prefer air/air, and not for bling factor.
