Posts: 45 |
My guess is a clutch noise, I've heard possible loose Cat. heat shield. Just wanted to see if any of you'all out there have had/fixed this problem. Again a metal, rattle noise, when leaving a stop in first gear, low RPM. Any help would be greatful. JC
Zippy Zetec on his last legs.
Posts: 1,262 |
i had that problem, it was the heatsheild on the upper side of my muffler. it had bent down and was rattling against the muffler. i still dont understand how the sheild bent tho...
Regards, Cole.
Relegating to troll status sometime this week.
New Whip: 1990 Lexus ES250.
Old Hotness: 1995 GL MTX Zetec *IN TRIAGE*
"I had a little friend once, but it dont move no more...  "
Posts: 45 |
Thanks... I'll take a look at that, I hope thats all it is, I wasn't ready to do a clutch quite yet....$$$  $$$.
Posts: 1,262 |
when i took off, it would rattle, when i depressed the clutch for the 1-2 shift, it woudl rattle.
Regards, Cole.
Posts: 652 |
Mine was more like a growling rattle that sounded like tranny in the gears or something, but when I replaced the clutch it went away. I think it was the spring dampeners in the clutch disc geting loose making the sounds from the tranny really come out. It would do the sound at low rpms when almost lugging a bit when taking off. At first I had tried the Synthetic mix in the trans but that didn't help. But after the clutch it was nice and quiet. The clutch wasn't slipping or anything, I just changed it because of that noise, and for preventive maintenance. I did it at around 130k I guess?
'95 CONTOUR SE
-Enkei 16s
-SVT wannabe
-Dual escapes w/ 2 1/2" stainless tips
-True LED taillight conversion
- Audi Xenon Projector Retrofit
-Mp3 deck, dual 10s
Posts: 45 |
Posts: 45 |
For those of you following this post I had my car looked at, and for this rattle, it was the lower Cat. the honey comb inside was loose and rattling.
problem solved.
Thanks for all the help!.
Posts: 144 |
Did they replace the cat? What was the cost on it?
98.5 Blk CSVT #6479
Posts: 45 |
Somthing I found out about the CAT. 8 years or 80,000 miles, is the emmisons warenty. My 98 SVT, has 71K so I fell into the warenty. If not a OEM Cat, from Ford is around 625.00.....ouch!!! Or just go to the SHO Shop, and get it for 99.00, and have a muffler shop weld it in for you. S#!T I could buy a whole new exhaust for 625.00.
