Page 2 of 3 1 2 3
Reverse Flow cooling has recently been used in some High Performance Engines such as the Chevrolet Corvette, and I believe that GM also used it in most of its V8 engines during the 90s.
The Buick RoadMaster from 92 on, used a 235HP variant of the Chevy Corvette 5.7L V8, but it was Throttle Body Injected, rather than Sequential Port Injected. The Collection Series of the RoadMaster, I believe, built for 1996 (last year built), has the Sequential Port Injected V8. All of these V8s were REVERSE FLOW COOLED. GM claimes that by reversing the coolant flow, the engine burned fuel more efficiently than with the conventional coolant flow.
Pete...
Pete...
98.5 SE Sport Duratec ATX (P66L)
Black Clearcoat on Greystone
DOB 11/21/1997
DOP 12/25/1997
PIAA 510 Super White Driving Lights
SVT CAT-BACK EXHAUST (No Resonator)
DiabloSport Chip (LPQ4) - Engineered To Raise Hell
Too many other mods to list...
Sounds sweet, runs quick...
Crazy Horse Dyno @ 121.4 WHP/129.6 TQ
N
NMC Offline
N
Roadrunner is correct. The idea is to hit the heads with the coolest coolant from the rad first and then the block. Keeping the heads cooler allows more ignition advance, thus more power. I think only the 350 in the Vette, Camaro and Firebird have it though.
As for running straight water, don't do it. The glycol and other additives also raise the boiling point and give corrosion protection. There is very little heat exchange when you've got steam in your pipes. Best mix is 50/50 if you don't get snow. I run 70/30 cause we hit -40 some days.
96LX/24V/ATX/Midnight Red/A4 repeaters/SVT exhaust/KKM/65mm throttlebody/SVTsprings and ST200 struts/SE rockers and BAT spoiler/BAT 19mm swaybar/urethane bushings/Kenwood 7 speaker syst./E1 SVT brakes w Powerslot rotors/9005 lowbeams/885 fogs/50% tint/Michelin XM+S 130's for winter/E1's with gForces for summer...and now "New Paint!!"
87 Renault GTA convertible/2.0l/mtx/Sony sound/otherwise stock
http://members.shaw.ca/neilmc/
Originally posted by SVTtheory2000:
would it be so much that polypropelyne glycol is ultra cool? i found that it is just a matter of that propelyne glycol has the ability to super heat, and the poly version does not superheat, therefore it can come in contact with the headers......
I believe you're talking about "Heads", not "Headers". Headers are smooth flowing tubular exhaust manifolds. Heads are what sits on top of the cylinders and also contain the valvetrain on most engines. Cooling the heads first makes sense for cars designed with the right computer in mind, but for our cars it may throw a pretty big wrench into the spokes. Todays OBD-II ECUs are very sensative to operating temps... many people of the Mustang GT crowd can attest to this... The 5.0 used to love a colder thermostat... try it on a 4.6 OBD-II car, and you'll run rich and loose performance without a serious reprogram on the computer. I'd venture to guess that the same could be said for the Contour or any other Ford car made today. If it's not overheating or taking to long to heat up, leave it be. wink
Brad Noon
'99 SE MTX
3 point oh my God H.O. 179HP/178TQ
BNMotorsports Floormats, powder coating, TB optimizing, Gutted cats, etc
BNMotorsports is now the preferred distributor of Contour/SVT/Mystique Indiglo style gauges!!!
bnmotorsports@msn.com
Polypropelyne (sp?) is a common plastic resin. I think that might poison your gerbils. smile
BB
'98 SVT #53 of 6535
Born on 3/26/97
Reborn 8/21/01
MODS:
Driver v 2.0
Antifreeze is Ethelyene Glycol, and it is very harmful to dogs. It is also costly to save one's dogs life if they decide to drink it, so keep that stuff under wraps and outta the way of your animals (I could care less about the kids cuz I don't have any :p )...yes Cleo is fine, just cost me a grand in Vet bills and hospital stay.
Just call me Judge.
People suck.
Life begins at 170mph...until that point it is just boring.....
Originally posted by Big Jim:
Propelene glycol is the stuff that some alternative anti freeze companies (such as Sierra) have been pushing claiming that it is more environmentally friendly. Claiming that it breaks down more quickly when released into the environment and is not as toxic.
Ethylene glycol is toxic and when left loose often poisons dogs and cats. Propylene glycol, on the other hand, is so nontoxic that it can be legally used as a food ingredient. The performance differences are small enough that I am baffled why most antifreeze sold is not propylene glycol. You only need ethylene glycol if you live someplace that gets like 50 degrees below zero.
Sierra is not an alternative company, by the way, it's just a brand used by one of the regular antifreeze companies for their propylene version.
96 GL Zetec ATX, white with pinstripe, nickname " Sam Smooth "
mods so far: CTA intake with homemade heat shield, KVR drilled front rotors & carbon pads w/ 500° fluid
planned mods: exhaust (want to keep it quiet), e-ram (awaiting installation), diablo chip
involuntary mods: compression increased after head gasket failure
Consumption + profit margin = sell the cheap stuff even though its toxic!
V6 MTX
'Its only nuts & bolts!'
Haines Motor Sports Inc,
thanks for the input everyone.....bnoon, roadrunner, and NMC are with me on this one and they seem to read me exactly with what i am talkin about, and what my question refers too, thanks guys for the input....
-chris-
96 gl: 18" adr reactions, SVT rear bumper & side-skirts, Magnaflow exhaust, CTA Intake, ACCEL coil, 9mm wires, Kenwood, Blaupunkt, Sony Xplod Mobile ES, OBX pedals w/dead pedal, neons, bnmotorsports gauges, autometer monster tach, and ZAINO!
Quicksilver wrote:
If your intentions are keeping the engine cool, than removing the anti-freeze, is your best bet, unless you live in freezing climates. Fortunately for me I live in Hawaii!
I simply drained all my coolant out and filled the radiator with only water + a little bottle of Amsoil RM125. This thing will scrub and clean every nook and cranny of my coolant system and since I don't experience frezzing temp. there is now no need for anti-freeze.
This can still be very bad if you use the A/C or defrost. The iar travelling over the heater core is well below freezing when the a/c is on. It is possible to freeze the heater core with the a/c.
Red Line with their water wettter (and amsoil with the product you mention), still recommend using about 25% antifreeze to protect against this problem. I'm guessing the systems that shut off the waterflow to the heater core when the heat is set tot cold are most vulnerable to this problem. I don't know the contour system well enough to know if it does this or allows the coolent to flow, but simply redirects the air.
Not a recommended path.
Richard
F
F
Plain water only for racing, that glycol is extremely splipery. ethylene much cheaper than than Polypro. I've forgotten the specs, but polypro's used in solar and dry coolers etc the big AC systems (building etc). ethylene stands up to the engine enviroment much better.
This Dex-cool stuff suppose to have a property that idea for heat transfer in the head area. As usual I've forgot the word!
Paul
Page 2 of 3 1 2 3
