Posts: 669 |
anyone ever haerd the ole saying that the guy who packs his headers in ice, wins.......or something like that.....well anyways i got to talking to a chemist and physicist about this......seems that propelyne glycol is used in anti-freeze, the main ingredient actaully.....well, i now know why they use propelyne glycol and not polypropelyne glycol.....anyways my point is i heard that you can reverse the order of the way your coolant flows and have it hit the headers first then the block, in turn you have to use polypropelyne glycol, and you actually get a horsepower boost.....anyone know anything about this mod? ever heard of doing this? any input would be wonderful.....thanks
chris
-chris- 96 gl: 18" adr reactions, SVT rear bumper & side-skirts, Magnaflow exhaust, CTA Intake, ACCEL coil, 9mm wires, Kenwood, Blaupunkt, Sony Xplod Mobile ES, OBX pedals w/dead pedal, neons, bnmotorsports gauges, autometer monster tach, and ZAINO!
Posts: 5,805 |
Very interesting things happen (thermal shock) when you hit hit valve seats/castings with 'ultra-cool coolant'!!
Posts: 669 |
would it be so much that polypropelyne glycol is ultra cool? i found that it is just a matter of that propelyne glycol has the ability to super heat, and the poly version does not superheat, therefore it can come in contact with the headers......
Posts: 329 |
Originally posted by Terry Haines: Very interesting things happen (thermal shock) when you hit hit valve seats/castings with 'ultra-cool coolant'!! And he's not talking power gains here... At all.
blk.99svt n.e.Ohio Never under estimate the power of stupid people in large groups...
Posts: 5,805 |
I think your theory has become a little mixed.You are proposing a water jacketed set of exhaust manifolds a la -marine engines correct?
Posts: 669 |
hey terry, i dont have any clue as to what you are talking about.....(my lack of knowledge showing here) you might have to explain more into what you mean.....i am basically just lookin for anyone's knowledge on this if they know anything about it, i heard that this mod had been done before, therefore i wasnt sure as to any of this, so i asked.....feel free to add anything you might know about this, thanks.
Administrator
Administrator
Posts: 5,037 |
You ice the intake because it's a big chunk of aluminum that the intake air goes through. If you where to "ice" the whole engine, you would warp lots-o-stuff.
Ever heard a valve pop? Get a 90 Mustang GT with open headers, drive around at WOT for about 30 minutes, then turn off the car when it's 25 degrees F outside. That cold air rushes in and hits the exhaust valve. It makes a loud pop.
Posts: 669 |
Ever heard a valve pop? Get a 90 Mustang GT with open headers, drive around at WOT for about 30 minutes, then turn off the car when it's 25 degrees F outside. That cold air rushes in and hits the exhaust valve. It makes a loud pop  interesting indeed
Posts: 667 |
If your intentions are keeping the engine cool, than removing the anti-freeze, is your best bet, unless you live in freezing climates. Fortunately for me I live in Hawaii! I simply drained all my coolant out and filled the radiator with only water + a little bottle of Amsoil RM125. This thing will scrub and clean every nook and cranny of my coolant system and since I don't experience frezzing temp. there is now no need for anti-freeze. Very interesting things happen (thermal shock) when you hit hit valve seats/castings with 'ultra-cool coolant'!! Hey Terry I experienced thermal shock one time at the Gym. I jumped from the ice-pool straight into the jacuzzi, what a JOLT!!! POOR ENGINE!!!!!!!!
Posts: 1,861 |
Did any of you bother to look at the ingredient list on a bottle of anti freeze? It's ethelene glycol.
Propelene glycol is the stuff that some alternative anti freeze companies (such as Sierra) have been pushing claiming that it is more environmentally friendly. Claiming that it breaks down more quickly when released into the environment and is not as toxic. It also does not have quite as good of a heat transfer ability (but close) and does not protect for freezing or overheating quite as well.
Anyway, it seems as though someone is pulling your chain.
Also, it helps to pack your intake manifold with ice, not the exhaust.
Jim Johnson 98 SVT
