Page 2 of 2 1 2
#1039566 09/13/04 03:36 PM
Y
Y
Would a Transgo CD4E jr. shift kit help his ATX at all? How about a new valve body? Just curious, my Contour has 125K so I'm probably next.
96 Contour 2.5L 148K ATX rebuilt 2X
#1039567 09/13/04 03:48 PM
Originally posted by starjammir:
I have the same problem with my 95 mystique. Cept my slipping is from 3-4. And my 1-2 gear when cold is the same as him with the abrupt shift. I just had my tranny flushed and that didnt do anything. Also i went to autozone to get my comp scanned and they said they cant do it because they cant find the plug for it. Where is the plug??
The plug for your 95 is under the hood.
Autozone will probably not be able to scan it because they only hae the scanner
for an OBD-II system, and your 95 is OBD-I.
Pete... 2004 Mercury Marauder 300A Black Clearcoat/Dark Charcoal LEATHER DOB 10/31/2003 DOP 1/2/2004 www.mercurymarauder.net
#1039568 09/13/04 03:50 PM
You will need BOTH as well as a full rebuild kit, and the new updated pump.
#1039569 09/13/04 11:35 PM
Well that isnt good for me so how can i tell if a sensor is bad or not in it??
1998.5 SVT contour #5979 3L 1995 Mercury Mystique 2.5L auto, all ghetto fo sho
#1039570 09/13/04 11:56 PM
First, the sensors in the 95 are different.
Second the early 95s were prone to blowing the pump pressure gasket.
There is a revised gasket and pump kit to replace the original and cure the gasket seal problem.
With the age and mileage of your vehicle, a full rebuild would be the best way to go.
Expecially if you haven't changed the Transaxle oil at least every 15,000 miles.
You would insure that you get all new clutches, seals, and a brand new valve body,
and have it reworked with the TransGo Shift Kit Jr.
You can also check on the condition of all of the bearings while you have it apart.
It is going to cost you, but in the end you'll have a reliably built transaxle
that will give you at least as much service as it already has, if not more.
And it will lsat even longer if you change the transaxle oil every 15,000 miles.
#1039571 09/14/04 02:27 PM
I have the 95 but only have about 58700 miles on it. I didnt think that the trannys would go that fast on them. It was an older couples car before mine and im not out there racing it or anything. So a full rebuld on it huh. Ill have to save up for that. Im really on a budget for that
#1039572 09/15/04 04:15 AM
On the 98 Contour SE Sport I had, the original tranny failed at 31,000 miles.
#1039573 09/15/04 02:07 PM
yeah but aren't you the official CD4E burner for CEG
98.5 Black SE ATX S&B filter, SVT MAF, optimized SVT TB, mesh grille, removed orange reflectors, painted rear reflector, gutted pre-cats, optimized SVT LIM, 19lb injectors, resonator removed cant afford an svt but lookin for 1 in nc
#1039574 09/15/04 02:29 PM
Yes I am the Official CD4E Burner and that title was self appointed.
I gave myself that title because I was the only one that I was aware of
that had 2 CD4E transaxles fail with less than 50,000 miles on each one.
I NEVER raced my Contour SE Sport or drove it in any AutoCross competitions,
although I would have like to very much.
I did have the car dynoed at Crazy Horse, about 3 months before the second CD4E failed on me.
It only dynoed at 129hp which was a lot less than I had expected.
This was a sign of what was coming.
So Yes, I am the *OFFICIAL* CD4E Burner, but not for abusive reasons.
Page 2 of 2 1 2
