Posts: 6,106 |
Ok, before my head explodes, go out to your car(that is if you really have one), OPEN YOUR HOOD! Now this should be obvious, but you will want to look at the fender that is RIGHT NEXT TO YOUR AIR FILTER!!!!!!!!! Now with that said, you answered your own question.. "AIR BOX FENDER DRAW" You do realize that your car has "fenders", and in that "fender" in which you have an "air box" you will see a "fender draw" which is a little piece of black plastic that is in your "fender".. To easily find this "fender draw" which is all too conveniently located in your "fender", take your "air box" out.. I believe the "fender draw" is held in with 2 or 3 Hex head screws.. Take them out, remove the "fender draw", and search before you ever post again.
2000 Black CSVT
Posts: 10,015 |
Originally posted by Y2KSVT: Ok, before my head explodes, go out to your car(that is if you really have one), OPEN YOUR HOOD! Now this should be obvious, but you will want to look at the fender that is RIGHT NEXT TO YOUR AIR FILTER!!!!!!!!! Now with that said, you answered your own question.. "AIR BOX FENDER DRAW" You do realize that your car has "fenders", and in that "fender" in which you have an "air box" you will see a "fender draw" which is a little piece of black plastic that is in your "fender".. To easily find this "fender draw" which is all too conveniently located in your "fender", take your "air box" out.. I believe the "fender draw" is held in with 2 or 3 Hex head screws.. Take them out, remove the "fender draw", and search before you ever post again.
His user name says it all!
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
Posts: 6,106 |
Originally posted by Stazi: Originally posted by Y2KSVT: Ok, before my head explodes, go out to your car(that is if you really have one), OPEN YOUR HOOD! Now this should be obvious, but you will want to look at the fender that is RIGHT NEXT TO YOUR AIR FILTER!!!!!!!!! Now with that said, you answered your own question.. "AIR BOX FENDER DRAW" You do realize that your car has "fenders", and in that "fender" in which you have an "air box" you will see a "fender draw" which is a little piece of black plastic that is in your "fender".. To easily find this "fender draw" which is all too conveniently located in your "fender", take your "air box" out.. I believe the "fender draw" is held in with 2 or 3 Hex head screws.. Take them out, remove the "fender draw", and search before you ever post again.
LOL! "Hi my name is Nimrod, and every post I make will back my name up 100%"
2000 Black CSVT
Posts: 200 |
hahahahaha
98 Contour SE 3.0L 5-speed
SCT PRP, Gutted IMRC's, Fidanza Flywheel, Race Ported 2004 3.0L Oval Port, Zex 125hp shot, 70mm Mustang TB, 42Lb injectors,Walbro 255 pump, Traction Bars, Zeitronix wideband o2, lots of little things, 10,000K HID's!!
Zippy Zetec on his last legs.
Posts: 1,262 |
there is also a resonator behind the inner fender well (the mud gard thnigy that keeps the inner fenders from getting all nasty)...so there is more than one.
Regards, Cole.
Relegating to troll status sometime this week.
New Whip: 1990 Lexus ES250.
Old Hotness: 1995 GL MTX Zetec *IN TRIAGE*
"I had a little friend once, but it dont move no more...  "
Posts: 8,301 |
Originally posted by Y2KSVT: Originally posted by Stazi: Originally posted by Y2KSVT: Ok, before my head explodes, go out to your car(that is if you really have one), OPEN YOUR HOOD! Now this should be obvious, but you will want to look at the fender that is RIGHT NEXT TO YOUR AIR FILTER!!!!!!!!! Now with that said, you answered your own question.. "AIR BOX FENDER DRAW" You do realize that your car has "fenders", and in that "fender" in which you have an "air box" you will see a "fender draw" which is a little piece of black plastic that is in your "fender".. To easily find this "fender draw" which is all too conveniently located in your "fender", take your "air box" out.. I believe the "fender draw" is held in with 2 or 3 Hex head screws.. Take them out, remove the "fender draw", and search before you ever post again.
Be nice, not everyone is a car expert If you think thats bad, you would probably end up killing some of my friends. They could not even point to the airbox, let alone the fender draw.
-Ken V.
psycho_bass@hotmail.com
Posts: 70 |
Posts: 432 |
The fender draw they're talking about is seen nicely in picture #2. On the right hand side of the picture, you can see it. It's to the right of the air box and above the power distribution box. Although if you're keeping the stock airbox I don't think you should remove the fender draw. Heh, I just noticed the "How to: Make your own HAI" title.
Bill
'00 SVT Black/Tan
Posts: 70 |
So is the resonator inside that fender?
Posts: 70 |
Are you refering to the fender as the black piece of rubber tube that is about two inches long?
